RV.Net Open Roads Forum: 24 ft or less B+ with over head bed.
Open Roads Forum  >  Class C Motorhomes  >  B+
 > 24 ft or less B+ with over head bed.
Page of 5
ron.dittmer
North-East Illinois
Posted: 06/21/21 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
I agree that the E450 is the best of the bunch. The only thing I would do concerning the extra rough ride in back on the lighter weighted rigs would be to "tune" the rear suspension to better match the actual load it carries. Too much extra capability will make a rough ride even more rough. Many RV owners complain about their rig thrashing around. Maybe something can be done to soften the ride.
How to "tune" the rear suspension is another topic involving the removal of the proper amount of E450 leaf springs. I have no personal experience to provide, only theories. I imagine it would begin by comparing the leaf spring packs of the E450 to the E350, learning what you can from the differences. Also compare your E450 actual rear axle weight to the limit of the E350 of the same model year. If you are rear axle weighs 1000 less than what an E350 rear axle can handle, then you want your leaf stacks to be that of an E350. Again, my theory alone.
* This post was last edited 06/21/21 04:43pm by ron.dittmer *   View edit history
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
atreis
IN
Posted: 06/21/21 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
I prefer to Chevy 4500. Much less tuning of the chasses required than the Ford, while still retaining the benefits of the wider rear track.
2021 Four Winds 26B on Chevy 4500
Gjac
Milford, CT
Posted: 06/21/21 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Does the 4500 and 3500 chassis have the same rear track as the Ford 450 and 350 chassis?
atreis
IN
Posted: 06/22/21 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know where to find the exact dimensions. Given that Thor builds the exact same motorhomes on the E350 and Chevy 4500 (and there's no visible difference at the rear) I'd guess it's close to the E350's width.
I also appreciate the 4500's much higher OCCC (vs. the E350 version). [emoticon]
pnichols
The Other California
Posted: 06/23/21 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder why Thor doesn't build on the E450 Ford cutaway chassis?
As I understand it Ford will still deliver E450 cutaway chassis, with their new V8, to Class C motorhome builders - but that Ford no longer offers complete E-Series vans.
Phil, 2005 E450 Itasca Spirit 24V
AJR
Close to Madison Wisconsin
Posted: 06/23/21 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
I don’t know. But my E350 RV had a lower entry step than my current 4500 chassis. I had to buy a step so entry was easier on this old man.
Gjac
After all these posts of what you are looking for. Are you just looking for responses? Or do you really have a plan for your next RV?
There have been a number of good responses, I think. Maybe you are just overthinking this whole issue.
Peace…
2014 Leprechaun 290QB
Chevy 4500 6.0
2015 GMC Terrain AWD
Gjac
Milford, CT
Posted: 06/24/21 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Gjac
Peace…
Over thinking is what I do. I made a few mistakes in my younger years for being impulsive. I am looking for a 22-24 ft MH, and have learned a few things from these responses. Chevy chassis have more room in the cockpit than Ford and reportedly ride better than a Ford Chassis without a lot of suspension mods. B plus's ride no better than a C of the same size. I never would have thought that before responses. Tail drag is something to look out for although I still don't know what is a good min GC to avoid this. Some report that newer C's have less of a problem. Storage and water are also important to me. Some C's have a huge storage bay in the rear and 50 gals of FW, B pluses don't. Still thinking about if a rear bed would work or a sideout with a queen is needed. To me going from an A to a small C is a big adjustment with a lot of things to consider. I have a MH now so I am in no hurry to buy a new one. I will wait until the economy changes and people are no longer enamored or can afford RV travel. I think by next year there will be a lot of MH's for sale and prices will be much lower.
DrewE
Vermont
Posted: 06/24/21 07:10am Link  |  Quote  |  Print  |  Notify Moderator
Tail drag is less about overall ground clearance (which is pretty much the same for most class C's, since the lowest point is under the axle), but rather the departure angle--the maximum angle up from the bottom of the rear tires to the bumper without encountering anything. My motorhome has significantly more ground clearance than my car, but it is vastly more likely to scrape the tail end and more likely to be high-pointed by a railroad crossing or similar short, fairly steep little hill.
Gjac
Milford, CT
Posted: 06/24/21 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
. I should have been more specific when I mention GC I meant from the hitch where it drags to the ground. I notice some transition up from the rear wheel to the hitch while some start to transition half way then more abruptly to the hitch. It does not appear to be a problem on the sprinter chassis with a longer wheel base and less overhang.
wintersun
Monterey
Posted: 06/24/21 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Check out the "Class C" motorhomes from Coachmen in both traditional C types with bunks over the cab and also B+ versions. They use the Ford E-350 chassis for some models and the Chevy 4500 for others so you have a choice of both as well as differing floor plans.
What I particularly like is their use of compressor fridges and propane cooktops and ovens. The 4500 RVs also have a 4000W generator and very large fuel tanks.
Page of 5
