RV.Net Open Roads Forum: Tech Issues: Coach step inc issues
 > Coach step inc issues
stew47
ohio
Posted: 06/03/21 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all. I have a 2007 Georgetown. Then steps will make a loud clicking sound and hesitate to go up. If I help steps it works. I crawled under and looks like gear teeth are worn. The steps part is 725 0023. Can I buy just the gear?
Flute Man
Payson, Arizona
Posted: 06/03/21 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
I would think so. Call step manufacture and order the parts.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
MrWizard
Traveling
Posted: 06/04/21 02:37am Link  |  Quote  |  Print  |  Notify Moderator
Don't know about "Coach Inc" brand
But Amazon and eBay have parts for various the kwickee step models a from lippert, Motors ,gears etc.
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
craig7h
Branson MO area
Posted: 06/04/21 02:59am Link  |  Quote  |  Print  |  Notify Moderator
Not doubting you but how can you see the teeth? I just had somewhat the same problem with my kwickee step. There are four bolts that hold the whole motor assembly to a metal plate, that is attached to the underside of the coach. On my step the four bolts had sheared off, and the motor was not being held on to the metal plate. You may have somewhat the same problem. Maybe not all four but enough to cause the action of the motor and its arm to not fully retract the step. The bolts were brass and I replaced them with metric #6 stainless steel bolts. Once completed the steps work as good as new.
Itasca Meridian SE 36g
Road Master Tow Dolly
William Willard
Brookins Oregon
Posted: 06/04/21 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Coach Step was purchased by Kwikee -- Go to etrailer.com -- They will have the part you need --
dougrainer
Carrolton, Texas
Posted: 06/04/21 09:34am Link  |  Quote  |  Print  |  Notify Moderator
I call that gear a "pie" gear. It is available from both LCI and E trailer. BUT!!!!!!! Have you had the recall done? It IS needed. This does not involve your current problem. Doug
https://static.nhtsa.gov/odi/rcl/2015/RCMN-15V798-6319.pdf
PS This recall is for ALL LCI Coachsteps, not just FR
stew47
ohio
Posted: 06/04/21 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Hello all. Dealer can’t find the “ fan “ gear for a 3 step. New kwikee is 1100 plus few hours for install. Sigh. Gonna keep looking at options. Thinking about removing bottom step since it always hits the ground. Probably what broke it. Also clean up the gear a little with a grinder.
dougrainer
Carrolton, Texas
Posted: 06/04/21 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
Get another dealer. Doug
https://store.lci1.com/coach-step-gear-plate-assemblies-164348.html
https://store.lci1.com/triple-coach-step-recall-parts-kit-389152.html
stew47
ohio
Posted: 06/04/21 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Doug, you’re awesome!! They just wanted me to drop grand and a half on some steps!
