RV.Net Open Roads Forum: Tech Issues: AC Question For Doug
 > AC Question For Doug
Bob Landry
Austin, texas
Posted: 06/04/21 05:28am Link  |  Quote  |  Print  |  Notify Moderator
I just installed a second AC in the fiver. This is a second unit so it is cool only, Coleman Mach15, ducted.
I had a mobil RV help me with the installation and for reference he did the wiring will I was working on something else.
Al of the modes work correctly. The problem is, when touching bat at the bottom to change modes, the numeric LED segments go dim and/or are washed out on the display by the back lighting. The unit will go into the selected mode and after a few seconds, the display returns to normal.
Is this a wiring issue or a defective thermostat?
2011 Keystone Outback 277RL
Flute Man
Payson, Arizona
Posted: 06/04/21 06:31am Link  |  Quote  |  Print  |  Notify Moderator
Does it do the same when raising or lowering the temperature?
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
Bob Landry
Austin, texas
Posted: 06/04/21 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Yes, and it does it if any button is pressed.
dougrainer
Carrolton, Texas
Posted: 06/04/21 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Never seen this. WHICH RVP Tstat do you have. They have about 20. Doug
Flute Man
Payson, Arizona
Posted: 06/04/21 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Might try reseating the connector on the thermostat and also at the other end where it plugs into the board. Sounds like you’ve got a drop in power supply voltage which probably comes off of the main board. I don’t know your particular system but that’s where I would start.
Jerry Parr
2112
Posted: 06/04/21 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Hey Bob
Nice to see you're still enjoying your 277RL. I had its sister. We bought ours at the same time close to the same place as I recall. I resealed all the hatches as you instructed and then she was stolen in 2012.
Take Care
Dave
2013 KZ Durango 2857
Bob Landry
Austin, texas
Posted: 06/04/21 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
Actually, I'm not enjoying it any longer. I traded a few months back for a Grand Design fiver.
Bob Landry
Austin, texas
Posted: 06/04/21 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
It's the 9430*340. It's a cool only thermostat. It came with Molex plugs but I had to cut them off and butt connect to the control cable. It was the only Cool Only t-stat I could find,
dougrainer
Carrolton, Texas
Posted: 06/04/21 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Try this. Make SURE you have 12 volts and NOT 8.1 volts. Doug
https://www.airxcel.com/DesktopModules/RvProduct/Pdf/t005.pdf
Bob Landry
Austin, texas
Posted: 06/04/21 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Just curious.. What is the significance of 8.1V? What would create that particular voltage?
