RV.Net Open Roads Forum: Tech Issues: AC Question For Doug
 > AC Question For Doug
Flute Man
Payson, Arizona
Posted: 06/04/21 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
Bob Landry wrote:
Just curious.. What is the significance of 8.1V? What would create that particular voltage?
Yes 8.1?
Jerry
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
2112
Posted: 06/05/21 05:05am Link  |  Quote  |  Print  |  Notify Moderator
Flute Man wrote:
Yes 8.1?
Jerry
Two shorted battery cells?
Minimum voltage for the tstat?
Inquiring minds what to know!
2013 KZ Durango 2857
dougrainer
Carrolton, Texas
Posted: 06/05/21 10:21am Link  |  Quote  |  Print  |  Notify Moderator
There are some RVP systems that utilize 8 volts to the tstat from the upper control board and THAT is normal. BUT only for the older mechanical wall tstats and not for more current LCD display. What I would do in your case is remove the Tstat and add 2 wires from the POS and NEG and connect to a Volt meter and see if the voltage drops from 12 volts when you experiance the DIMMING. IF NOT, then I would say the tstat is bad. If it does drop you have a bad ground or POS connection somewhere. Even the minimal milliamp draw of the tstat LCD causing a volt draw would be amazing to cause a bad connection to cause the volt drop. But, I guess it can happen. Maybe your GROUND to the tstat is NOT a real ground. Another way, is to run a 2 wire connection from your 12 volt fuse center and connect 12 volt POS and NEG at the Fuse center and run to the tstat to verify a GOOD voltage connection. You stated YOU did not run the tstat wires. Doug
Bob Landry
Austin, texas
Posted: 06/05/21 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Several things to look at. The 12V wires were provided by the manuf. and were already in place, as was the thermostat cable. The thermostat came with molex connectors so I had to cut those off and butt connect to the t-stat cable. I was able to match colors so there was no confusion there. We did check for proper voltage on the 12V wiring they provided. I'm going back this weekend to double check everything. Thanks to all for all of the info.
2011 Keystone Outback 277RL
dougrainer
Carrolton, Texas
Posted: 06/05/21 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
When the OEM supplies a prewire, they rarely connect the 12 volt POS and NEG to a power source. Doug
Bob Landry
Austin, texas
Posted: 09/04/21 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
That is correct. I had to tie into a 12V wire for a ceiling light which Grand Design had pulled close to the location There was also a 115V wire there. This is standard on Grand Design units prewired for a 2nd AC.
Anyway... Here's an update.
As stated above, the thermostat has functioned correctly since installation. It appears that the LED segments and backlight function correctly when the room temp hits 70 or lower. Anything above 70 and the brightness of the LEDs and backlight become close to the samebrightness and the Tstat is barely readable.
I'm going with a bad thermostat. Wierd,,
