RV.Net Open Roads Forum: About to leave, truck batteries are dead question
 > About to leave, truck batteries are dead question
mattyj
Long Island.New York
Posted: 06/04/21 06:48am Link  |  Quote  |  Print  |  Notify Moderator
Hello everyone, I loaded the camper last night packed everything up had the truck running idling for a while no problem. Today I go to start truck batteries are dead and I can’t figure why the meter is saying the camper battery is OK, lights work.Can anybody help me with this? Thanks
2006 Ford F 350, 6.0 PSD 8 Foot Bed 4x4 with Torklift Tie downs and Stable Loads 2004 Lancelite 835 ,a/c ,electric jacks , conveince/all weather packages
joerg68
St. Ingbert, Germany
Posted: 06/04/21 07:08am Link  |  Quote  |  Print  |  Notify Moderator
The one thing that will run down the batteries in no time is a 3-way fridge running on 12V at 120-200 watts. Can you exclude that as a reason?
First, unplug camper to eliminate any cause from that side.
What voltage do the truck batteries read?
What voltage does the camper battery read?
How old are the batteries?
Do they accept a a charge? Either from an external charger or from the truck alternator after a jump start?
Possibilities:
Truck battery died
Lights or other electrical device left on
Excessive load from camper, see beginning of my post (but that doesn't seem to rhyme well with your story)
Not a professional here, better opinions welcome.
Dick_B
Palos Heights, IL USA
Posted: 06/04/21 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Not much to go on but we had battery problems with our Suburban due to electronics using juice overnight even tho we supposedly had everything else turned off.
How old is the truck battery? Did you accidentally leave a dome light on overnight?
Better to get the battery tested by a pro. My auto dealer told me that they find bad batteries in the new cars just off the truck :-(
* This post was edited 06/04/21 07:25am by Dick_B *
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
mattyj
Posted: 06/04/21 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for responses the battery in the camper is new in the truck batteries are new I am not going to go get a tester and try to check the voltage
mattyj
Posted: 06/04/21 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Correction I am now going to test the batteries
joerg68
Posted: 06/04/21 07:14am Link  |  Quote  |  Print  |  Notify Moderator
I amended my first reply, pse re-read if you haven't yet.
NRALIFR
Truck Camping Out West
Posted: 06/04/21 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, start with checking the battery’s voltage. Disconnect one of the cables on each battery and check each one separately.
Are there any accessories connected directly to either battery?
Normally on Ford’s, the 12v charging circuit from the truck is running through a relay that isolates the camper from the truck when the engine isn’t running. It’s not hard to defeat that though of you want to. As joerg said, make sure it’s not the camper that ran the truck batteries down.
[emoticon][emoticon]
* This post was edited 06/04/21 07:25am by NRALIFR *
2001 Lance 1121 on a 2016 F450 ‘Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam types………..Let’s Go Brandon!!!
mattyj
Posted: 06/04/21 07:38am Link  |  Quote  |  Print  |  Notify Moderator
The truck batteries are 11.38 volts and the camper battery is 12.56 if anyone can help me.
mattyj
Posted: 06/04/21 07:43am Link  |  Quote  |  Print  |  Notify Moderator
. I had to camper plugged in to AC at my house and I just jump started the truck and it started and I shut it down 15 minutes later it won’t start again
mattyj
Posted: 06/04/21 07:44am Link  |  Quote  |  Print  |  Notify Moderator
I will disconnect each battery on the truck and test again when I tested the first time they were connected thanks
