RV.Net Open Roads Forum: 1998 Safari Serengeti electric diagram or schematic
 > 1998 Safari Serengeti electric diagram or schematic
Pmahl
Chicago
Posted: 06/04/21 10:26am Link  |  Quote  |  Print  |  Notify Moderator
I am a new owner of a 1998 Safari Serengeti dp. I am having electric issues with my generator and am looking for any type of diagram or schematic to help trace back my problem. Any help is appreciated.
Peter
MountainAir05
New Mexico
Posted: 06/04/21 10:32am Link  |  Quote  |  Print  |  Notify Moderator
need a name on The generator and model # if you are talking about the aux gen for the RV. If for the engine the same info. What is it not doing.
Maybe here:
https://www.irv2.com/forums/f115/wiring-diagram-for-1998-safari-serengenti-289903.html
* This post was edited 06/04/21 10:39am by MountainAir05 *
Pmahl
Chicago
Posted: 06/04/21 11:53am Link  |  Quote  |  Print  |  Notify Moderator
I should have included that info. It is an Onan 7500 diesel generator. There is nothing happening when using the toggle to start it from inside the coach.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 06/04/21 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Does it start from outside?
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
MrWizard
Traveling
Posted: 06/04/21 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Probable cause is dirty or loose connection where the remote wiring plugs into the Onan,
Unplug connector, and spray it with contact cleaner,
Spray both sides the wiring harness plug, and the mating side on the onan
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
