RV.Net Open Roads Forum: Class C Motorhomes: Fuel delivery issues carbureted Ford 460
 > Fuel delivery issues carbureted Ford 460
Ghank1956
29566
Posted: 06/04/21 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Engine is flooding, backfired and blew muffler apart, has an electric fuel pump
Dusty R
Charlotte Michigan 48813
Posted: 06/04/21 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Have no idea what kind of fuel system it has but it sounds like it's getting too much fuel. If it has a carburetor the float valve is leaking or the float is not floating, which is allowing too much gas into the engine.
bobndot
Posted: 06/04/21 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
dusty x2. might be time to rebuild the carb.
J&R
jefferson,ga
Posted: 06/04/21 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
ethenol gas will destroy carbs, large or small engines.
Ron & Joanne 06 Revolution LE 40E
Gary45
Oshawa, Ontario, Canada
Posted: 06/04/21 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Float needle probably needs replacing
wolfe10
Posted: 06/04/21 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Please tell us what year your Ford 460 is.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Posted: 06/04/21 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Possibly timing as well.
2017 Heartland Torque T29
Ghank1956
29566
Posted: 06/05/21 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
1985 fleetwood tioga
Ghank1956
29566
Posted: 06/05/21 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
It is a 460 with a 4180 carb built by Holley. I was told there were issues with vapor lock and Ford put a “fuel vapor control valve” on these units that is supposed to return fuel to the tank, I am thinking it may be the problem but can’t find any info on them. My local dealer says they are obsolete.
bobndot
Posted: 06/05/21 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Try 460Ford.com they have a lot of related info.
