RV.Net Open Roads Forum: Solar & Inverter starting point advice
Search only in Public Lands, Boondocking and ...
Open Roads Forum  >  Public Lands, Boondocking and Dry Camping
 > Solar & Inverter starting point advice
kfp673
PA
Posted: 06/04/21 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Hello All,
We seem to be dry camping more and more over the past 2 years. Mostly in state forrest land with dedicated sites but the sites are roughly 1/4-1/2 mile between each site. This spring I upgraded from a single 12v to dual 6V batteries. Now when camping in 40 degree nights my furnace makes it well into the morning and even into the afternoon vs 3 or 4am with the old 12v. So our current routine is running generator for about 2 hours in the morning while we make coffee and breakfast, and then about 2 hours in the evening as my kids are winding down and watching a movie before bed. The rest of the day and all night I prefer to leave generators off and 4 hours seems to be enough to charge the batteries enough to hold over another night.
Anyway,I'd love to cut that back even further and give the ability to run a coffee maker, TV, and other devices off 12v. Please point me in a direction of where to start looking at inverters. Are there good posts explaining how and where to install them? Also, what size solar kit is fairly affordable and makes enough power to maybe cut an hour or two off my generator running?
Thanks!
agwill
enosburg falls, vt
Posted: 06/04/21 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
For most of all your questions you can find all the information you are looking for on You Tube. I would have you look up, Renogy is a good starter but there are many others to chose from. From a 100 watt starter package for less than $200 to a 400 watt system for around $600.
al
Ivylog
Blairsville, GA and WPB, FL.
Posted: 06/04/21 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Unless you are full time, the payback on solar is never and you can forget making coffee off your 2 batteries... run the generator. Without adding more batteries, adding solar will only help a little.
A 500W inverter will power the TV. The cheapest way to decrease generator time is add a bigger battery charger.
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
D.E.Bishop
Eagle Rock, CA
Posted: 06/04/21 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have two Interstate GC2 batteries and charge them using a Windy City 200 Watt 2 panel solar setup for right at $225.. We can go for several days up to at least 10 and only use the Generator for making toast in the morning and occasionally use it for running the microwave.
A 500 watt inverter is way more than you need to run an average 32" Class TV. My older 120 VAC Sharp TV uses 45 amps of power. The 32" Class Insignia I had in our Bounder was 12 VDC and used 35
Watts. The Winnie has a 100 Watt inverter and runs the Blu-Ray and TV with ease.
The best way to power a coffee maker is use a percolator. If you like K-Cups, use a Cup-A-Joe for 15 bucks from Walmart.
While I may never get my money back on these things, I don't use the genny very often and thereby avoid the ire of the self-righteous Generator Police.
The best power savers are LED lights and I converted 5 fluorescent ceiling lights to two power level LED lights for les than 20 bucks for a 15 foot strip from eBay.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
Quartzsite, AZ
Posted: 06/04/21 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
“Anyway,I'd love to cut that back even further and give the ability to run a coffee maker, TV, and other devices off 12v.”
Four batteries and 600 watts of solar will accomplish all of the above 98 days out of a hundred without any generator use. Depending on how late you sleep solar will be recharging your batteries before you wake up. The “payback” is you don’t worry about electricity, gasoline, oil level or changes. I’m at 75 days with no generator use.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
theoldwizard1
SE MI
Posted: 06/04/21 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
The very FIRST thing you need is a GOOD battery monitor. Victron makes several from basic to ones with lots of "wiz bangs". Even the basic one, BMV-700, is good !
Once installed you will know how much energy you really ARE using !
Boon Docker
Posted: 06/04/21 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
If you boondock a lot solar is the best way to go.
dieseltruckdriver
Black Hills of SD
Posted: 06/04/21 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have 400 watts of solar, two 12 volt AGM batteries, a Victron BMV 702 battery monitor, Victron 375 watt inverter and LOVE IT!
Last night it paid for itself in full. Just like last summer. No worrying about the generator noise, hauling gas, and we can watch as much tv or run the furnace as much as we want. The inverter only powers one outlet, and that is for the tv and a power strip to recharge laptops etc. It also has a remote switch so I can turn it off when it isn't needed.
I am going to add a couple hundred more watts of solar, but mainly for early spring or cloudy days. Honestly 400 watts is all we need, I just want more.
Coffee is always done with the percolator. That makes the best coffee ever!
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
wanderingaimlessly
Buggs Island lake
Posted: 06/04/21 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
On the coffeemaker
If you want a drip unit many of the small ones only used around 500 watts to start and after a couple minutes drop to 300 or so. And the "keep warm" cycle on mine uses about 300 watts for 10 seconds on and about 30 seconds off.
Otherwise use a single cup unit which only needs about 4 minutes to make a cup.
pianotuna
Regina, SK, Canada
Posted: 06/04/21 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
This website may help design a good system:
https://freecampsites.net/adding-solar/
Regards, Don
