RV.Net Open Roads Forum: Where is fuel leak on Onan Diesel Generator
 > Where is fuel leak on Onan Diesel Generator
bigred1cav
ohio
Posted: 06/04/21 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
My 2001 39' Bounder is leaking fuel from the Gen I to date have been unable to find that rascal.
Where do you think it is most likely to be found?
mobeewan
Hampton, Va
Posted: 06/04/21 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
If the RV came with the generator installed as original equipment it probably draws fuel from the RV fuel tank.
BarneyS
S.E. Lower Michigan
Posted: 06/04/21 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
Moved to Tech Issues forum from DIY.
MrWizard
Traveling
Posted: 06/12/21 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
How well does the Onan run, does it act flooded
Check the carb for a bad float
Check fuel hose to carb, might find a crack
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
bigred1cav
ohio
Posted: 06/13/21 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
We can't get it started yet. pre covid we ran it 24 hrs day for a when off hookup
bigred1cav
ohio
Posted: 06/28/21 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all. found it fuel line. now my alternate is not producing
wopachop
Who run bartertown
Posted: 06/28/21 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Are you saying the new fuel line is not producing fuel to the carb?
bigred1cav
ohio
Posted: 06/30/21 07:45am Link  |  Quote  |  Print  |  Notify Moderator
yes
wolfe10
Posted: 06/30/21 11:53am Link  |  Quote  |  Print  |  Notify Moderator
We have to be missing something here.
Title says DIESEL Onan Generator.
And comments by others as well as OP are discussing carburetors/gasoline issues.
Please tell us exactly what generator you have. And, is the problem a fuel leak and/or a no start.
If no start, how far into the "run" cycle do you get:
Fuel pump clicks?
generator turns over at low or normal speed?
generator starts and runs or dies?
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Posted: 06/30/21 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
^Yup, pretty sure it's fuel injected. Thanks for getting the crowd back on track.
As for diagnosis help, OP, please describe your issue in as clear of detail as possible.
"found it. alternat is no producing" does not help anyone help you.
* This post was edited 06/30/21 07:54pm by Grit dog *
2017 Heartland Torque T29
