brianseay1
Bridgeport, Ala USA
I have an Onan 7500 super quite diesel generator that will not stay running. It will start with no problem, but it will run for about a minute and then die. But it will start right back up and run again for the same amount of time. After about 8-9 starts it did stay running for about 20-25 minutes and then died again. started it right back up and it ran for about a minute and died, done this several times. It has a new fuel filter and the fuel in it was put in back in march. I always park it on a full tank. The coach engine runs just fine and they both run off the same fuel system. I have a small video of what it is doing. The sound is very loud but you can hear me start it, ear it running and hear it die. And then hear me restart it. I can't figure out how to download the video though.Any help is greatly appreciated.
edited 06/04/21 04:28pm by brianseay1 *
Brian & Neena & B.G.
B.G. 2014 Goldendoodle
2007 Coachmen Cross Country 389DS
300 HP Cummins Turbo Charged
03 Sahara Jeep Wrangler & 05 Harley Davidson Ultra Classic
2014 800 RZR4
Roll Tide Roll
2oldman
NM
Perhaps your generator's carburetor is quiet gummed up.
brianseay1
Bridgeport, Ala USA
It’s a diesel generator.
Ranger Smith
Wherever the rig is parked
2oldman wrote: Perhaps your generator's carburetor is quiet gummed up.
Diesel generator . . . No Carb. What is it throwing for a code. Sounds like it is maybe sucking air from somewhere or bad low oil pressure cutoff switch.
Where we are now
Amateur Radio Operator N1JS . . . SunSDR2 Dx, Ameritron AL-80 Amp, Icom 7100,Flex 6400m
Steve and Joy
2010 Allegro Bus 43 QBP . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
jdc1
Rescue, Ca
Disconnect the fuel pump and see what pressure it's putting out.
brianseay1
Bridgeport, Ala USA
It’s not throwing a code that I know of. Nothing comes up on the dash when it dies.
ROBERTSUNRUS
Salem, Oregon
Hi, low oil?????
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
:That is a classic symptom of clogged filter,, Need more info to decide if air or fuel. Or a collapsed fuel line.
Ranger Smith
brianseay1 wrote: It’s not throwing a code that I know of. Nothing comes up on the dash when it dies.
Code would be flashing lights on the start switch light
brianseay1
Bridgeport, Ala USA
Ranger Smith wrote: brianseay1 wrote: It’s not throwing a code that I know of. Nothing comes up on the dash when it dies.
Ok, it is throwing a code then. I noticed the start button light flashing but didn't realize that's what it was doing. Where can a find a copy of what the codes are ? I just thought it was flashing like it does when the injectors are pre-heating for start up.
