RV.Net Open Roads Forum: Tech Issues: what voltage for the 'house'?
 > what voltage for the 'house'?
pianotuna
Regina, SK, Canada
Posted: 06/04/21 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
https://getlitbatteries.com/12v-vs-48v-w........kKwaikqhOzaeCbBJpf1yop08JTvjuhBVcnEJ7qVo
Regards, Don
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 06/04/21 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Years ago I worked on 120+ volt DC systems. Series string 3 cell and even single cell batteries. Every voltage has its positive and negative advantages. Chuckle.
pianotuna
Regina, SK, Canada
Posted: 06/04/21 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Mex,
I could not agree more.
CA Traveler
The Western States
Posted: 06/04/21 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
A very few RVers have a 48V solar, inverter, charger and battery. And a 48V to 12V DC to DC for the house.
My Morningstar solar controller is limited to 60A output. That's 60*12 = 720W for a 12V output. If I switched to 48V then the limit is 60*48 = 2880W for that controller.
While 2880W is a lot of power for boondocking, not so much for utility power:
a 20A utility plug is 2400W, 30A is 3600W and 50A is 12000W available 24/7.
Update: Per suggestion the above voltages are generic for comparison and actual battery charging voltages vary based on a number of factors including battery temperature. [emoticon]
* This post was last edited 06/05/21 09:20am by CA Traveler *   View edit history
2014 Grand Cherokee Overland
Bob
2oldman
NM
Posted: 06/04/21 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
Cool
MrWizard
Traveling
Posted: 06/05/21 05:30am Link  |  Quote  |  Print  |  Notify Moderator
Bob , don't you mean 60a*14v 840 watts
You know you can't charge 12v battery with 12v,bit requires a voltage, above battery nominal full charge which is 12.6v,
A fully charged fla battery should read 13+v when charging is turn off
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
BobsYourUncle
Calgary Alberta Canada
Posted: 06/05/21 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Great article Don, thanks for posting.
I like the SXS comparison in easy to understand language.
I have been following solar and optimum configurations for a while, wanting to learn more, as we want to build an off grid support system for our Tango.
This article helps a lot.
Not a cheap venture at 4500 bucks for a battery! I'm sure the price will come down as more things like this become widespread in use.
Good stuff. [emoticon]
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
CA Traveler
The Western States
Posted: 06/05/21 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Of course but the post was intended to emphasis the difference between 12V and 48V in terms of the controller output and the nominal solar panel wattage. But perhaps I should have qualified these are the generic voltages and I have now updated the post.
In that context what voltage would you suggest? 14.0, 14.4, 14.8, 56.0, 57.6, 59.2 or some other voltage which is dependent on the various mfg specs, not to mention that the voltage is also temperature dependent.
Or the commonly used terms of 12 or 48 volt battery systems. There is no one size fits all.
* This post was edited 06/05/21 08:55am by CA Traveler *
2oldman
NM
Posted: 06/05/21 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Keeping the amps as low as possible was my goal. Wire handles voltage much better than amperage.
pianotuna
Regina, SK, Canada
Posted: 06/05/21 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Bob,
Thanks.
As you probably know I'm in the SiO2 camp due to cold weather. I'll have more than 7 kwh based on 80% depth of discharge.
If you have a couple of years wait time, you may want to consider Aluminum Ion batteries. They charge 60 times faster than Li and are 3 times the energy density.
