RV.Net Open Roads Forum: how long to lower temps When living quarters at 100
 > how long to lower temps When living quarters at 100
mrad
Prineton, MN
Posted: 06/04/21 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
We did a two hour pool today in 90 to 97° weather. When we got to our destinations the interior of the fifth wheel was pretty much 100° all over according to my infrared heat gun. After two hours it only dropped a couple of degrees. I have two 15,000 BTU air conditioners. One in the bedroom, one in the garage of the toy hauler. At first I had the turbo cool closed so it was using the ducts. But after having a little success cooling it down. I open the turbo cool in both the bedroom in the garage hoping to cool them down and pull the heat out of the walls and then try to cool down the living room dining room area later this evening when it cools down.
Just wondering if this is normal for two 15,000 BTU air conditioners in a 43 foot unit, or if there might be something wrong with the units
wildtoad
Blythewood, SC
Posted: 06/04/21 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
It will take a long time to cool the inside of an RV if the inside temp is that hot especially since the outside temp is still hot and working against the ac units. Measure the air temp at the return side of the unit versus the output side. If the return temp is say 95, and the output side is 75ish then the units are doing all they can do. Not sure where you are, but find some shade!
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
pianotuna
Regina, SK, Canada
Posted: 06/04/21 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
It generally takes a long long time. Consider starting the generator, and running the roof air for an hour before you stop for the day.
Regards, Don
Old-Biscuit
Verde Valley
Posted: 06/04/21 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Heat soak.....
Walls, floors, cabinets, ceiling, furniture etc etc
Dumping the cool air directly downward will bring temps down quicker due to the volume of cool air
THAT is why when we are traveling in HOT temps......our A/C is on via our generator
Nice to have cool 5vr when stopping for lunch and when setting up at CG
Winter travel...furnace is on
US NAVY------USS Decatur DDG31
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 06/04/21 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Having a veritable environmental lab's worth of recording instruments on a wall I notice that the humidity must drop before the temperature starts to move downward.
The temperature starts dropping very slowly once humidity reaches 60%. If enough BTU extraction is provided, the temp drop increases once the humidity reaches 50%.
But ceiling and wall Delta T will offset temp gain. The main. Benefit being a reduction in humidity. After I connected an 80-pint dehumidifier the cooldown was faster. But that Delta T and percentage of humidity makes simple calculations difficult.
My casita under construction is going to be firred out in 2x4 with closed cell foam. It's all shaded under a large Parrota tree.
When living in the tropics in a bare concrete dwelling life means the school of hard knocks. My bus cools down much faster at night. I parked it cross ways to the tradewinds.
time2roll
Posted: 06/04/21 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
For a heat soaked RV it is common to take an extended period to cool down. I figure four+ hours after sundown before you feel a chill. Never turn the A/C off in those conditions.
675w Solar pictures back up
Acampingwewillgo
Posted: 06/04/21 11:39pm Link  |  Quote  |  Print  |  Notify Moderator
One thing I've done when the sun is just plain unrelenting,where possible....spray the RV down with the hose. I know some places would frown on this but in places where they don't mind, it does help. Wet down the area around the RV too...as in gravel/dirt.
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund.
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie, Mollie, Elvis, Potter and Rosie Love You! (40+ years in all)
Posted: 06/05/21 05:12am Link  |  Quote  |  Print  |  Notify Moderator
I had a 38 foot class A. My wife choose the outside color (kind of brown and green) and the two 13,500s did not stand a chance of keeping it cool. I upgraded to a pair of 15000s and still not much improvement. Just not enough cool...
I learned to "Siesta" in the afternoons.
LouLawrence
Traveling the US!
Posted: 06/05/21 07:31am Link  |  Quote  |  Print  |  Notify Moderator
2 A/C units for an RV of that size is going to provide minimal cooling. If a 3rd A/C unit is an option it will make a dramatic improvement if you plan to do a lot of hot weather camping. If that's not an option or you don't do that kind of heat too often then running the genset and A/C at least a few hours before arrival will help a lot. I would use the air dump option during travels and then return to ducted A/C when you are going to occupy the unit.
2oldman
NM
Posted: 06/05/21 08:36am Link  |  Quote  |  Print  |  Notify Moderator
At 75 it will take forever. Mine's 55, constantly. I measured it.
