RV.Net Open Roads Forum: how long to lower temps When living quarters at 100
 > how long to lower temps When living quarters at 100
dougrainer
Carrolton, Texas
Posted: 06/05/21 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
Acampingwewillgo wrote:
Just to dispel some myths....37' non slide well insulated motorhome, two 15,000 btu roof top airs, awnings out, shares down, exterior window shades and a misting system on patio awning. The place, Pahrump, Nevada, the outside temp, hovering at about 115, inside RV, 68 degrees!
I've owned our motor home for close to 20 years and I travel in hot months....so it's not a one time occurrence!
The myth dispelled....that air can only cool down 20 degrees below outside temp! The accepted rule of thumb is 20 degrees less than the Ambien air entering your return air duct of your unit( up to its max cooling ability). That's my real world experience and my I understanding as to how it all works....your results will, in fact, vary!! LoL
You are correct BUT, you cannot compare your RV and length to RV's built LONGER (43 versus your 37) AND you have no slides Which is a GOOD thing because slide rooms are big air leakers even if they do not leak water inside. Doug
Acampingwewillgo
Posted: 06/05/21 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Your right Doug...I wouldn't begin to compare my 37' to a longer slide coach but I only posted this because getting a coach/RV cooled from a standing 100+ degree interior is a task for any cooling system. My reasoning is that it's a multi prong approach to get max cooling....the more you RV in heat, the more you learn!
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund.
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie, Mollie, Elvis, Potter and Rosie Love You! (40+ years in all)
JoeH
Apollo Beach,FL
Posted: 06/06/21 06:22am Link  |  Quote  |  Print  |  Notify Moderator
dougrainer wrote:
43 foot RV whether 5th or Motorhome requires 3 roof AC units in hot weather. Doug
I agree ! --- a few things you might want to do is to put insulated coverings on all the windows and to travel with vents open . That way the inside will be close to ambient temp vs a closed box with sun coming in the windows which will heat it up past ambient temp. Then when you stop and plug in you are at least starting out with ambient temp interior , but 2 AC's are going to struggle in a 43' rv
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
time2roll
Posted: 06/06/21 11:17am Link  |  Quote  |  Print  |  Notify Moderator
If that 43' RV had a generator... the A/C should have been running in transit.
675w Solar pictures back up
lwbfl
Florida Panhandle
Posted: 06/06/21 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
I've lived in Florida my entire life, camping for 35 years. The inside of my camper is usually higher than the outside temp once we stop. Here is what works for me: Travel with the vents open whenever possible (vent covers with lots of ventilation area!) As soon as we stop, I open the doors, windows and vents to let the heat out. Fire up the A/C and a fan if you have one and let it push out the heat while you finish setting up. Once set up, close everything back and let the A/C work. Sit on front of a fan with a cold drink until you cool down from all that hard work!
1976 Myself and Wife
2009 DD
3 Doggies
2016 Chevy Z71
2021 Coachmen Apex 253RLS
Mike134
Elgin, IL
Posted: 06/06/21 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
wildtoad wrote:
Measure the air temp at the return side of the unit versus the output side. If the return temp is say 95, and the output side is 75ish then the units are doing all they can do.
X2!!
this guy has your answer, I'd take the same measurements on your home's A/C to see if it's cooling correctly.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
wintersun
Monterey
Posted: 06/06/21 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
AC units for buildings are usually size so that there is a 20 degrees of cooling from the ambient temperature. With an RV the problem can be that the AC units are not sized correctly or have too short a cycle time. It takes time to remove the moisture from the air and cool down the interior spaces and sometimes a lower BTU rated unit that runs "continuously" works better than a high BTU AC.
Most RV's are built for "3-season" use and so not insulated for temperatures below freezing and so also not going to be great when temperatures are over 100 degrees. The advantage of an RV is that it can be moved to where the outside temperatures are warmer or cooler.
I grew up without air conditioning in my houses or my cars and trucks and it was not something that bothered me all that much. Friends with homes in the desert did not have AC either. Now AC is considered a necessity in the USA and so we use more electricity and add more to global warming which is not a good cycle to be in for us or for future generations.
If one is planning to spend months in the desert then building a structure to provide shade is worth considering. I see this often with trailers in areas where there is a snow load to worry about and the similar protection could be provided against solar loads.
On a more immediate basis if you can locate the RV so the rear is to the south then there will be less wall area exposed directly to the sun and having the side with the awning facing southwest would also help, if you have an awning.
* This post was edited 06/06/21 03:28pm by wintersun *
2oldman
NM
Posted: 06/06/21 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
If any of my a/c are blowing 75° air for more than a couple minutes, they're not functioning properly.
smthbros
WI
Posted: 06/07/21 11:50am Link  |  Quote  |  Print  |  Notify Moderator
For what its worth, a 20° temp drop for the air over the evaporator is not, in and of itself, proof of a properly functioning system. The temp drop is a variable commodity based on a few factors, primarily:
1- The latent heat load of the air across the evaporator.
The greater the relative humidity of that air, the less the temp
drop. As the AC removes the latent load, the temp drop will
increase. As MEX posted, latent load takes priority.
2- The volume of air across the evaporator.
The greater the CFM of air, the less the temp drop. A dirty coil
or filter would increase the temp drop.
If you have not done so lately, now would be a good time to clean the condenser as well.
azdryheat
Tucson, AZ
Posted: 06/07/21 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have all my windows covered with silver insulating pads that are cut to shape. Works great at keeping the interior cooler when the trailer isn't in use. One thing about our trailers, the builders love to put in huge windows to let in the heat and cold.
What I had to do to my toyhauler was to properly seal the air vents to keep the cold air from going into the attic area. They did a terrible job of taping at the Voltage factory but once I corrected their sloppy work the A/C works a whole lot better.
One thing I've seen at the RV shows I work is the higher-end 5th wheels are much better insulated. The Tiffin Beacon has thicker walls and double pane glass. Also the Redwoods are very nice in triple digits but you're going to pay for the comfort.
