RV.Net Open Roads Forum: Towing: Weight Distribution Hitch
Search only in Towing
Open Roads Forum  >  Towing
 > Weight Distribution Hitch
Caboostanley
Portland, Oregon
Posted: 06/05/21 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Greetings,
Hopefully, someone on here can help me. I need to install a weight distribution hitch in order to safely tow my travel trailer; however, my driveway is not long enough, so my tow vehicle is not level. My question is does the tow vehicle have to be level to install the hitch? I'm not sure how to get around this issue, assuming it's vital to setting up the hitch properly.
Thanks!
Chris
Portland, OR
Ivylog
Blairsville, GA and WPB, FL.
Posted: 06/05/21 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
There is no difference in level and flat ground for setting up the hitch. Once you figure out the settings for the bars... when on flat ground, no.
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
June Lake area, California
Posted: 06/05/21 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Install almost anywhere. Adjust on level ground. TV and TT should both be level when finished.
lwbfl
Florida Panhandle
Posted: 06/05/21 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Caboostanley wrote:
Greetings,
Thanks!
Chris
Portland, OR
Yes, you'll need to have both units level in order to properly set up the hitch. P.S. I have no idea what the previous poster is trying to say.
1976 Myself and Wife
2009 DD
3 Doggies
2016 Chevy Z71
2021 Coachmen Apex 253RLS
Posted: 06/05/21 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
^Hes saying once you know the setting then it doesn’t matter where you hook it up at.
OP, go set it up in a flat area. You can tow your trailer somewhere close by without being all strapped up belt n suspenders (wdh).
2017 Heartland Torque T29
Lynnmor
Red Lion
Posted: 06/05/21 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
If you are on a flat surface that is reasonably level you can make the adjustments. Get it close and then take your tools with you and find a parking lot to do the final work. Don’t use a level, instead use a tape measure and make your trailer parallel to the pavement.
Tyler0215
Iowa
Posted: 06/05/21 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Find a nearby parking lot (I used a nearby church lot) and take your tools with you.
goducks10
There
Posted: 06/06/21 11:35am Link  |  Quote  |  Print  |  Notify Moderator
FWIW level isn't parallel. You want the TT to be parallel to the ground.
Find a flat spot to do the initial setup then use those parameters anywhere you hitch up.
lwbfl
Florida Panhandle
Posted: 06/06/21 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
When I posted that I was the third comment. So the one I didn't understand was "no difference in flat or level when setting up". Although true, it had no bearing on the OP's question.
aftermath
Washington State
Posted: 06/07/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
This is it. The street in front of my house is not "level" but it is straight. Think about that for a minute. I set up my hitch doing exactly what Lynnmor described. I have checked it many times on "nearly level" ground and it is just fine.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
