RV.Net Open Roads Forum: Towing: Weight Distribution Hitch
Search only in Towing
Open Roads Forum  >  Towing
 > Weight Distribution Hitch
Posted: 06/07/21 09:01am Link  |  Quote  |  Print  |  Notify Moderator
lwbfl wrote:
Grit dog wrote:
^Hes saying once you know the setting then it doesn’t matter where you hook it up at.
OP, go set it up in a flat area. You can tow your trailer somewhere close by without being all strapped up belt n suspenders (wdh).
When I posted that I was the third comment. So the one I didn't understand was "no difference in flat or level when setting up". Although true, it had no bearing on the OP's question.
No worries, it was a bit cornfussing!
aftermath makes a good point. Level area doesn't really matter, just flat, as in no slope breaks in the surface. Within reason of course...
2017 Heartland Torque T29
Posted: 06/07/21 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Real question is what are you towing and with what? How do you know it would be unsafe to tow it naked? (No wdh)
