RV.Net Open Roads Forum: Fifth-Wheels: Batteries not holding charge ???
 > Batteries not holding charge ???
ilvtravln
Calif.
Posted: 06/05/21 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
I have 2 year old deep cycle Interstate batteries, usually they hold a charge for about 2 months but recently its much shorter than before. Is there a way to check the RV charging system? When I plug into power everything lights up normal. I check the water in the often. I plug into power about every 2 months. Last set of the same brand of batteries lasted 4 or 5 years. I called Costco where I bought them and they said warranty was only for 1 year. Thanks for any help.
* This post was last edited 06/06/21 12:40pm by ilvtravln *   View edit history
Art
Near Bishop, California
Posted: 06/05/21 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
I’m not sure your issue is charging. Have the batteries tested. Did you recharge every two months when they very low or nearly dead?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 06/05/21 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
You don't happen to have a storage bay light that got on by mistake, or something that's drawing power?
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
ilvtravln
Calif.
Posted: 06/05/21 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing is on. Thanks
Posted: 06/05/21 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
Solar makes keeping batteries charged so easy. My TT is neither on the 300 watt roof main system or, when covered, on the 30 watt panel on top of my cover.
2oldman
Nevada
Posted: 06/05/21 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
It's not unusual for acid batteries to lose capacity much faster than you think. Do you work them pretty hard?
Ed9824v
Agua Dulce, Calif. 70 mi N.E. of Los Angeles
Posted: 06/05/21 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
I am sure you checked the water in the batteries?
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
CA Traveler
The Western States
Posted: 06/05/21 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
Idiot lights are for the salesman to explain what a great charging system the RV has...
Buy a digital voltmeter for $10-20. With a dishcarged battery the battery voltage at the battery terminals should ramp up to 14.4V (bulk charging), then hold at 14.4V while the amps taper down (absorb charging) and then volts and amps taper down to float mode of 13.6V.
There are many posts on chargers that don't charge correctly especially WFCO and many have replaced that alleged charger.
If the plates are not completely covered with water the batteries are compromised. Have the batteries load tested by a good battery shop, an auto store is not a good battery shop.
2014 Grand Cherokee Overland
Bob
ilvtravln
Calif.
Posted: 06/06/21 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
I did plug into power about every 2 months, have not tested the batteries. Thanks
ilvtravln
Calif.
Posted: 06/06/21 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
No
