RV.Net Open Roads Forum: Tech Issues: Soft start for ac
 > Soft start for ac
lucy6194
Cape cod MA
Posted: 06/06/21 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Will be dry camping next Feb in key west Florida so obviously will need AC. I have on board generator plus two Honda 2000s that can be hooked together, however they take up slot of space and my 3500 generator weighs to much for me to lift alone. The on board is propane and to refill would require breaking down camp to get refilled. Am considering a soft start for the AC. I am a single woman camper with little electrical knowledge. Who or were would I get to install this and is it worth the money?
Near DVNP, California
Posted: 06/06/21 09:02am Link  |  Quote  |  Print  |  Notify Moderator
They work well. Any RV repair outfit should be able to install. Shop for a good price. Try mobile techs too.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
pianotuna
Regina, SK, Canada
Posted: 06/06/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
The soft start may not allow you to run from a single Honda 2000.
Regards, Don
theoldwizard1
SE MI
Posted: 06/06/21 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
BUYER BEWARE !
There are two types of "soft starters". Only the Micro-Air EasyStart is proven to work.
Also, you might consider selling your two Honda 2000 generators and replacing them with a Westinghouse iGen2500. Watch this video Westinghouse iGen2500 Vs Predator 3500 (Which To Buy)
There are some useful links in the description below this video.
* This post was edited 06/06/21 02:01pm by theoldwizard1 *
philh
Belleville MI
Posted: 06/06/21 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
microair EZ start is worth every penny and not particularly difficult to install.
I have a westinghouse 2500 and it would start and run a 15k AC unit after I modified. You might get lucking with a honda 2200 without modifying the air, or might not.
ktmrfs
Portland, Oregon
Posted: 06/09/21 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
at sea level our honda 2000 consistently starts our coleman Mach III while in eco mode. The AC has the micro air easy start installed.
Above about 4,000ft the 2000 is marginal, but the 2200 is fine all the way up to at least 7,000ft.
But make sure any other high loads are off, like make sure batteries are near full charge, etc.
With the 2,000 you won't be able to run much else other then the AC
2011 Keystone Outback 295RE
mr_andyj
Georgia
Posted: 06/10/21 08:38am Link  |  Quote  |  Print  |  Notify Moderator
How long will you be camping? It might be easier to just convert the propane system to be able to connect auxiliary tanks to supplement your propane. How many 20 pound bbq propane tanks would you need to have to make this trip work? The bbq tanks can be exchanged at almost any gas station or store in FL, or they can be refilled, and are easy to carry.
I figure if you take out two generators and their gas cans that you could fit 3 bbq tanks in their place.
The soft start things work. They are meant to lessen the power surge needed for starting only, nothing will reduce how much power the AC needs to continue running, so the little one 2000 will not run a 13.5 btu AC even if you can get it started. Generally you want extra capacity on the generator so it is not running at near 100% just to power your AC. A 50% load is more ideal.
Do not take it to an RV mechanic necessarily, this is not an RV thing, it is HVAC or electrical, foreign to most RV mechanics.
Any common every-day electrician will be able to install this as it is simple simple for them.
Any HVAC guy can also install this. Call around and take RV to them, they might be willing to do this, but you picked a bad time of year as HVAC guys are in peak demand right now.
If your brother-in-law is handy then he should be able to do the install. It is not rocket science.
Itinerant1
Itinerant
Posted: 06/10/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
X2 on being able to run a 15k A/C unit with the micro-air easy start with no problems as stated above with either the eu2000i or eu2200i generator.
Also, adding a micro-air easy start is not rocket science even for a beginner, between their instruction and all of the you tube videos it can be accomplished. [emoticon]
12v 500ah (5,120Wh usable), 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 1,800+ cycles.
vermilye
Oswego, NY, USA
Posted: 06/10/21 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Another advantage of the Micro Air Easy Start is it eliminates the "thump" when the compressor starts. Even if you are plugged into a pedestal, that makes sleeping a bit more comfortable.
Jon Vermilye My Travel Blog
My Photo & RV link blog
pianotuna
Regina, SK, Canada
Posted: 06/10/21 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
vermilye,
I had solved that with the autoformer. Things seemed to get worse after the micro air unit was installed. I've tweeked the autoformer to cut in a 113 instead of 110.
 > Soft start for ac
