RV.Net Open Roads Forum: Tech Issues: Fantastic Fan Thermostat error
 > Fantastic Fan Thermostat error
mr_andyj
Georgia
Posted: 06/06/21 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
I have to set the temp setting very high for the fan to come on. Is there a fix?
I found this out of stock switch but not sure it is the exact fit, I think it is. Im sure I can find this item, but would rather fix mine since it will allow the fan to come on.
Its 80 in the cabin, I have to set the temp to almost the very highest setting for fan to come on. It used to work down to the 60's or so for the cool setting if I remember.
I have seen others just put a regular wall mounted thermostat, but Im not willing to take the ceiling pieces apart to run new wires.
Dick_B
Palos Heights, IL USA
Posted: 06/06/21 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Just slightly off topic but would you, could you, replace the t/s with an on/off switch?
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
StarkNaked
West Seattle, WA
Posted: 06/07/21 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Contact Dometic parts department. They own Fan-Tastic Vent now.
https://www.dometic.com/en/se/support/spare-parts
Let us know if you have success getting the part you need.
MrWizard
Traveling
Posted: 06/07/21 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
If it's a simple mechanical thermostat it's just a bimetal strip with contacts, the temp adjust can set either the gap between contacts or the preload against the movement of the strip to close the contacts, I would start by removing the stat from fan and cleaning the contacts
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
mr_andyj
Georgia
Posted: 06/08/21 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
I will try this before calling Dometic.
Side note - the fan has 3 speeds. Fast is power directly to the fan, while med and slow go through what looks like a heating element of two different sizes. I assume this "burns" off some power which then reduces the power to the fan and thus a slower speed. Conclusion, all 3 speeds use the same amount of power. Conclusion, it is better to use the high speed while the thermostat is on for maintaining temps while you are away (it will run less than a slower speed). Use the slow and medium speeds for comfort/noise level while inside.
or does fast use the least power?
mr_andyj
Georgia
Posted: 06/08/21 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
Took it apart. The on/off switch is keeping it from dropping down very far. I can see the contacts. Not sure what cleaning them will do since I know it works. The contacts is what I can hear click, it just seems to click too late - it is not that hot yet I have to set the temp almost all the way high for it to come on. It used to come on lower.
To do more I will have to disassemble from the roof. I may or may not do that.
