RV.Net Open Roads Forum: Travel Trailers: ANTS
IB853347201
Eastern Ontario
Posted: 06/07/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
bukhrn wrote:
I use this, https://www.homedepot.com/p/TERRO-Indoor........d-Ant-Killer-Baits-1-Pack-T300/202532940 it's some awesome stuff, once they find it, they take it back to their nest and kills off all their relatives.
We often run into Ants in our travels. TERRO works everytime!
2010 Suncruiser
Anza-Borrego Desert SP area
Posted: 06/07/21 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
What a mess! Sorry it happened. Campfire ash around the wheels and tongue works for me to keep them OUT!
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
ford truck guy
Pennsylvania
Posted: 06/07/21 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
I have used these also with GREAT RESULTS.. BUT - - Those are huge!! they look like carpenter ants . . Not sure they would fit???
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
wildtoad
Blythewood, SC
Posted: 06/07/21 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
There are animal(and human) bug sprays that you could use to treat the inside of you RV. Ants found a way to get in perhaps power cord, dump hose, cable/sat connection. Taking care of them outside is best.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
obgraham
TriCites WA
Posted: 06/07/21 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Raid. Redose if necessary. Then move on with life.
Ants are part and parcel of life.
Oregun
Oregon
Posted: 06/07/21 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
You may have more than an ant problem. Ants like wet wood. Check if you have any leaks from inside/outside.
parker.rowe
Delaware
Posted: 06/07/21 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
Terro has worked great for us for everything EXCEPT carpenter ants.
I read they only go after sweet things during a certain times so baits don't always work well with them. It's also why they don't always seem to go after food like other ants.
Other ants Terro will wipe them out in 24hrs, it's like magic.
Carpenter ants I've always had to kill the old fashion way, with windex or bug spray.
2015 Starcraft TravelStar 239TBS 6500 GVWR
1997 GMC Suburban K2500 7.4 Vortec/4.10
1977 Kawasaki KZ1000
esox07
Wisconsin
Posted: 06/07/21 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I went in again today and notice two on the linoleum floor. Nothing but dead ones in the water tank storage area. I put 4 Terro baits out. They do have big enough openings for these ants. I hope they work. If not, I will have to try something else.
Minnesota Viking fan trapped in Wisconsin
2011 KZ Sportsmen Classic 19BH
2013 Chevy Silverado 1500, Ext Cab, 5.3L Z71, 4x4
Boliy 3600si
AAA Plus RV
Sjm9911
New Jersey
Posted: 06/08/21 05:04am Link  |  Quote  |  Print  |  Notify Moderator
I xant see from the pictures but big black ants are carpenter ants. They need stronger stuff to kill then the ant bait traps. They do have granular aint bait to kill them, also spray the whole thing inside and out with like ortho home defense. As stated they nest in wet wood. And can do some damage to wood.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Dick_B
Palos Heights, IL USA
Posted: 06/08/21 06:29am Link  |  Quote  |  Print  |  Notify Moderator
X2 on the Terro Liquid ant baits which has always worked for us either at home or on the rv. Since the bait is food there will be a larger number of the critters shortly after the packages are set around but in a day or to they will be gone.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
