RV.Net Open Roads Forum: Fifth-Wheels: Moving to a 5th Wheel
 > Moving to a 5th Wheel
Page of 5
FootSoldier
Scottsdale, AZ
Posted: 06/07/21 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
The wife and I are looking down the road a little at a time when neither of us will have to go to work. The thought is to buy a new/newer 3/4 ton diesel truck to pull a 5th wheel trailer.
We won't be full-timers, but there's a lot of this great country we want to go see. I'm thinking 33-34' max, with a budget of $60k max for the trailer. We don't need luxury, but we do want convenience.
We've been camping in a Rockwood Roo 23SS since 2013. We love the little trailer, but I am nearing 69 and don't want a workout just setting up camp.
Like everyone else, I want our $$ to go toward quality and am trying to figure out if there are brands we should head toward or brands we should head away from? Or, are they really all the same in our price range?
At the moment, based on pics and floor plans, I lean toward the Rockwood Ultra Lite 2881S at 33'. I prefer no slides on the door side and the biggest awning we can get.
What about buying something? Where's the best places to search? We bought our 23SS online and had it delivered from Ohio for $2-3k less than we could buy it locally.
Please chime in and help educate me?
Thanks for any help!
Cummins12V98
on the road
Posted: 06/07/21 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
Get the RV you like “THEN” get the truck that has the capacity to safely tow it.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Lantley
Ellicott City, Maryland
Posted: 06/08/21 05:08am Link  |  Quote  |  Print  |  Notify Moderator
Buy a 1 ton truck vs. a 3/4 ton truck. You want the additional payload capacity
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
theoldwizard1
SE MI
Posted: 06/08/21 05:23am Link  |  Quote  |  Print  |  Notify Moderator
Newer diesel trucks do NOT get the same fuel economy as older ones. Plus you have to add the cost if DEF and very expensive oil changes.
way2roll
Wilmington NC
Posted: 06/08/21 05:41am Link  |  Quote  |  Print  |  Notify Moderator
Fuel efficiency in new diesels is greatly improved over previous years especially paired with the newer transmissions.
valhalla360
No paticular place.
Posted: 06/08/21 06:27am Link  |  Quote  |  Print  |  Notify Moderator
This is why you find the trailer first...particularly with 5th wheels.
Expect the pin weight to be somewhere on the order of 25% of the trailer GVWR for a 5th wheel (ignore the empty pin weight listed in the brochure as it has nothing to do with real life towing). A 14,000lb GVWR trailer will have around a 3500lb pin weight. Add in 200lb for the hitch and you have already used 3700lb of the trucks payload.
2021 F250 Crew Cab Long Bed (Platinum) only has a payload of around 3000-3600 depending how it's outfitted. Yet the tow rating can be up to 21,700lb.
Even some of the single rear wheel F350's are only in the 3300-4300 range.
If you find one with 4300lb payload, you have 600lb for passengers and other gear in the truck. Your typical family of 4 with 2 teen boys can easily weigh in at 600lb. Firewood, spare gas, generator, grills, etc... in the truck and even with max payload you need to move up to a dually if you want to stay within the specs on the truck.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Second Chance
Wherever...
Posted: 06/08/21 06:40am Link  |  Quote  |  Print  |  Notify Moderator
DEF costs me about $40/year. How are the oil changes any more expensive than a pre-DEF truck? The same oil designed for diesel engines is used. The most expensive part of the service on my truck is fuel filter changes - and I would do those whether it is a pre- or post-DEF truck. As for fuel mileage, with a 1-ton DRW truck with a 6-speed and 373 rear end, I get 17 - 18 on the highway not towing and 10 - 11 MPG towing a high-profile 15k (on the scales) fifth wheel.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
way2roll
Wilmington NC
Posted: 06/08/21 06:58am Link  |  Quote  |  Print  |  Notify Moderator
This is good advice. However, timing can be a bit tricky right now. If you bought a FW you may find yourself waiting for a while on a truck as the supply chain issues and high demand make them very hard to find right now.
TXiceman
Full Time RVer
Posted: 06/08/21 07:09am Link  |  Quote  |  Print  |  Notify Moderator
As already noted, select a trailer first then the trailer. In any case, I'd get a 1 ton single rear wheel rather than a 3/4 ton truck. A 3/4 ton truck is very limited in payload and rear axle capacity to carry the pin weight. Max trailer for a 3/4 ton truck will be about a 35' lighter weight trailer.
Use 20% of the trailers GVWR to estimate the trailer pin weight rather than the brochure fiction weights. Also, you can not go by the truck manufacturer's towing capacity. A 3/4 ton truck will reach it maximum payload capacity long before it reaches it's towing capacity. Get the truck manufacturers towing guide and study it and learn all of the terms.
And lastly, ignore the truck and RV sales person on what you can safely tow. If their lips are moving, they are lying.
Ken
Amateur Radio Operator.
2oldman
So Cal
Posted: 06/08/21 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Ultra light trailers are not built for lasting quality. The heavier the better, and 5th wheels are work setting up.
I advise getting leveling jacks. Leveling a 5er with boards and plastic squares is work.
Page of 5
