RV.Net Open Roads Forum: Fifth-Wheels: Stuck Caliper Piston
 > Stuck Caliper Piston
cummins2014
Utah
Posted: 06/08/21 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Well here goes again , a leaking tire on the fifth wheel got all this started, while the tire was off thought I would pull the hub to see what size grease seals I would need to pack the bearings. What I discovered was a broken plastic dust cap, and worn out disc brakes. Bought the four new grease seals ,and 2 new sets of disc brake pads.
All went well on the first one ,packed the bearings ,changed the pads ,I put a clamp on the caliper piston to push it back to give me enough room to get the caliper back on , no problems . Proceded on the second one, got to the part where I clamp the piston back for more clearance, and it will absolutely not move, even put a cheater on the clamp no go. Never had a caliper piston before that couldn't be pushed back in . Anyone have any suggestions how to get that piston to release ??
Home Skillet
Pearland Texas
Posted: 06/08/21 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Just replace the caliper.
A sticking caliper will make the pads drag, causing over heated brakes.
Or, loosen the bleeder screw while pushing the piston in.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
cummins2014
Utah
Posted: 06/08/21 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I'll see if the bleeder screw will let it go, that was my next move, but thought there might be other ideas , but leaning toward a new caliper.
cummins2014
Utah
Posted: 06/09/21 11:18am Link  |  Quote  |  Print  |  Notify Moderator
All's good , more operator error then anything. I usually use some adjustable welders clamps or just a C-clamp. Putting pressure just on one side of the piston, has always worked, not this time . Well google is a wonderful thing , placed a piece of 1/4" plate across the piston .and put on the c-clamp in the center, and it went right in like it should, no froze piston after all.
Learned something today. Although I did the axle behind like I usually do without a problem.
94-D2
Sutter Creek ca
Posted: 06/12/21 01:38am Link  |  Quote  |  Print  |  Notify Moderator
I always use the old brake pad to center the pistons to push in. Works every time....
2018 Ram 3500 Crew Cab Laramie 6.7L, Aisin, air ride, Ram puck prep, SuperGlide 20K auto slide.
2018 Bighorn Traveler 4 slide w/Apt.
It’s not what you’ve done that commands respect, it’s what you do.
Happy Campin’
Tvov
CT
Posted: 06/12/21 04:27am Link  |  Quote  |  Print  |  Notify Moderator
LOL! After all these years, I never thought of that. I always seem to search for a more complicated solution!
2008 F-250 CrewCab 5.4L,
opnspaces
San Diego Ca
Posted: 06/12/21 09:00am Link  |  Quote  |  Print  |  Notify Moderator
94-D2 beat me too it. I always use an old brake pad to both center the pistons as well as protect them from damage.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Cummins12V98
on the road
Posted: 06/12/21 11:34am Link  |  Quote  |  Print  |  Notify Moderator
Clamping the edge for sure can cause the piston to bind.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
cummins2014
Utah
Posted: 06/12/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
And I’ve pushed in more pistons then I can count , and that was a first pushing on the edge and binding . I’ll for sure never give one a chance again .
John&Joey
Summer-North,Winter-South
Posted: 06/12/21 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I would replace the caliper. Very possible the piston has rust on it. If the seal doesn’t look perfect,then that’s the problem. Might be able to push it in, but it won’t be right.
