RV.Net Open Roads Forum: Truck Campers: Are you towing with a flatbed?
 > Are you towing with a flatbed?
mt-ed
Montaha
Posted: 06/08/21 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
Greetings all, I'd like to know if anyone has mounted their truck camper on a flatbed, and also has some arrangement for towing as well? It seems that all I'm finding are hitches for regular bed pickups.
I'll also throw out there, that I have a Ford F550 as well, and I suspect that throws another wrench into the works too.
Thanks in advance!
fpoole
PNW and Beyond
Posted: 06/08/21 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
I luv the camper on a trailer idea too.
I have the camper on a flatbed and just tow a little 7x14 open trailer with a SxS on it, no problem.
Hitch receiver, 2" was installed on the flat bed with a 22" extension to the trailer due to camper overhang.
I would guess any big hitch place would be able to install anything you need.....
Frank Poole
Roam'n ROG (Full Timer since Oct '15)
2016 RAM 5500, C/c, 6.7 Diesel, AISIN HD 6-spd, 19.5 DRW, 72 Gal fuel, 4x4, 10’ Alum FB, 440 Amps, 4.10 Axle
2016 AF 990 640-Solar/10-6v Batts
GlowStep Stow N’ Go, E-Bike
RS1 Buggy
frank
Pooles website
Joe Glidewell
Mississippi
Posted: 06/09/21 06:28am Link  |  Quote  |  Print  |  Notify Moderator
Would I be correct in assuming your question is directed toward a flatbed body that doesn't have a rear drop down area below the axles?
* This post was last edited 06/09/21 12:52pm by Joe Glidewell *   View edit history
mkirsch
Rochester, NY
Posted: 06/09/21 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Receivers are available for standard frame trucks like your F550. Etrailer is one place that sells them. You can go plug in any year Ford F550 cab and chassis and get a list of recommendations.
Even if you had a flatbed on a pickup truck frame, the receiver bolts to the FRAME of the truck, not the pickup bed.
Near DVNP, California
Posted: 06/09/21 08:00am Link  |  Quote  |  Print  |  Notify Moderator
I see very few and Joe’s is the first fairly good looking I’ve encountered.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Posted: 06/09/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Thanks in advance!
Lots of campers on flatbeds and I’m not sure I’ve ever seen a F550 without a trailer hitch receiver, so sort of confused by your question.
You have a bare chassis cab currently?
You have a flatbed on the truck but no hitch receiver?
You have any idea of the length of bed, camper, rear overhang that you’re proposing or thinking about?
2017 Heartland Torque T29
n0arp
FT
Posted: 06/09/21 09:59am Link  |  Quote  |  Print  |  Notify Moderator
I'm picking up a custom flatbed tomorrow, so we'll see how that goes. As part of the customization process, I had them delete the standard 2" receiver it comes with and fabricate the bed so that the factory 2.5" receiver remains in place. I use a 48" extension (drilled at 42") that fits into a 2.5" receiver and has a 2" receiver on the other end.
If you're towing with a lot of tongue weight, you probably need to look at the SuperHitch or similar and have the truck bed built or modified as to not interfere with it. We're just flat towing a Jeep, so the tongue weight is minimal.
2021 Ram 5500 Limited 84CA Cummins 4x4 w/ flatbed
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
mike/kellie
northern calif.
Posted: 06/09/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Towing with utility body on Ram 5500
https://i.imgur.com/bHVWRt5l.jpg
2015 Host Mammoth triple slide w/ TorkLift Fastguns
2015 Ram 5500 SLT cab & chassis with Douglass 9' utility body
mike/kellie
northern calif.
Posted: 06/09/21 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Trying this from my phone
https://www.rv.net/forum/index.cfm/fuseaction/editorFunctions/mode/link.cfm
jimh425
Western MT
Posted: 06/09/21 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
mike/kellie here you go.
