RV.Net Open Roads Forum: Tow Vehicles: When to change oil
Search only in Tow Vehicles
 > When to change oil
Page of 8
p220sigman
Tallahassee, FL, USA
Posted: 06/11/21 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
FishOnOne wrote:
Grit dog wrote:
This thread gets funnier by the day!
It really does... [emoticon]
And the irony is that the vast majority of people change the oil (or more likely have it changed) when the vehicle tells them it is time.
Posted: 06/11/21 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Except 4x and that other guy who posted he goes double. I don't do UOA's. Don't care. I change on time or a little early or whatever my spidey sense says. Since the oil I'm "wasting" by not extending due to UOA or the 4x4ord theory costs me maybe 5 hundredths of one percent of my annual income. Or 0.0005/100.
Serious question. If Ram says 15k and Frod says 10k miles OCI, is the additional wear on Ford oil really 33% more, IE are Fords really 33% harder on the oil?
2017 Heartland Torque T29
larry barnhart
wenatchee. wa usa
Posted: 06/11/21 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
I change our Duramax's oil when this 80 year old body tells me and that time is very close. Once a year usually less than 7000 miles. Only drive it in the winter in Az for the 6 months we are there. Missed this last season but just maybe again this late September we hit the road. chevman
chevman
2019 rockwood 34 ft fifth wheel
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
kellem
Shenandoah valley,VA
Posted: 06/11/21 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Retired and change oil once per year on every engine on the property.....don't drive much.
4x4ord
Alberta
Posted: 06/12/21 05:54am Link  |  Quote  |  Print  |  Notify Moderator
My question as well. Although unlikely, one possibility is that the Powerstroke runs at hotter temperatures which could conceivably cause oil to deteriorate quicker. Another possibility that I think might be more likely is that Ford comes up with their oil change interval based on automotive standards whereas Cummins comes up with Rams oil change intervals based on industrial standards. Industrial powered equipment often has 600 hr change intervals. These engines are used at about 80 to 110 % rated load all day long and often run in extremely dusty conditions. My spider sense tells me that North America car manufacturers make a lot of money off the service department and if they were to recommend extended oil change intervals they would loose out on a lot of money.
2021 F350 SRW Platinum short box 4x4.
B&W Companion
cummins2014
Utah
Posted: 06/12/21 07:54am Link  |  Quote  |  Print  |  Notify Moderator
You think its funny here ,you should hear 12V ,and the boys over on turbo diesel forum. They haven't even got into the debate about socket size for the front fuel filter here yet , whether you should go 28MM or 1*1/8" [emoticon] . But the oil filter from the top or bottom is still the most highly contested debate, Oh ,and Amsoil !!!!!!!
Lynnmor
Red Lion
Posted: 06/12/21 08:07am Link  |  Quote  |  Print  |  Notify Moderator
1-1/8" is way too loose, let the debate start here. [emoticon]
cummins2014
Utah
Posted: 06/12/21 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Yup, but some insist its good enough .
Groover
Pulaski, TN
Posted: 06/12/21 08:57am Link  |  Quote  |  Print  |  Notify Moderator
I hate it when I go into a car dealer and they have big signs in the service department saying that they recommend changing oil ever 5,000 miles, regardless of what the manufacturer says. That proves to me that your theory them putting profit ahead of need is correct.
ktmrfs
Portland, Oregon
Posted: 06/12/21 09:31am Link  |  Quote  |  Print  |  Notify Moderator
On the recomended change interval or the onboard oil life. I think there are many parts to this.
1) What detailed oil analysis and careful monitoring yields for oil life
2) What consumers will accept for change interval.
3) typical mileage/year for vehicles.
IMHO (2) wins out. For decades of "you must change oil every 3K miles" getting people to accept a 5K, 7500, 10K or longer oil change interval is hard.
GM solved (3) by having the DIC drop 2%/week to meet the "change the oil at least once/year". Some other mfg still have the once/year interval or DIC, but don't monitor time. I have once such vehicle, with covid we only drove it about 5K miles last year, oil life was down to 50%, but it had hit the one year mark, and no dash indicator to change oil.
2011 Keystone Outback 295RE
Page of 8
