RV.Net Open Roads Forum: Tech Issues: half of my outlets not working
 > half of my outlets not working
davecoloradosprings
colorado
Posted: 06/09/21 08:22am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2007 Northwoods Nash 22GQ travel trailer. Out last weekend and we heard a pop in our trailer. Like a breaker went off. I checked the power center and yes, there was a breaker that tripped. I reset it. I then went to the GFCI outlet and hit the reset button on that. Did not fix the issue. So, I went back to the power control center, checked all fuses, all good, and then tripped the breaker that i had done earlier. This breaker wont stay 'on'. I can barely touch it and it will trip. So, I am thinking that the breaker needs to be replaced. Or maybe its the GFCI outlet that has gone bad? Any thoughts would be greatly appreciated.
Quartzsite, AZ
Posted: 06/09/21 08:31am Link  |  Quote  |  Print  |  Notify Moderator
That’s where I’d start...replace the breaker.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
capacitor
California
Posted: 06/09/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Trip the GFI then see if the breaker is still touchy. If so replace. If not replace GFI. Unplug everything in that circuit first.
DrewE
Vermont
Posted: 06/09/21 09:06am Link  |  Quote  |  Print  |  Notify Moderator
As the breaker is tripping immediately, there are a few possibilities:
1. Bad breaker, with no other cause; I'd guess this is probably the least likely, but it certainly is not impossible. In general, though, circuit breakers are very reliable if not abused by being exposed to the elements, repeatedly switched under load, or that sort of thing.
2. A short or significant overload somewhere in the circuit, such that the breaker is doing its job and protecting you. Find and correct. This could be tricky to find, if it's due to e.g. a wire being chafed on the RV frame somewhere or a staple or screw penetrating it.
3. A loose connection between the breaker and the bus bar in the power center, or between the circuit wire and the breaker. Current flow would cause a poor connection to heat up, and a thermal-magnetic breaker to warm up, and trip at well under its rated current. Fix the bad connection (which may involve replacing the breaker and/or bus bar and/or wire if they have been damaged by heat). It is not a bad idea to check all the connections for tightness every now and again--of course, with power disconnected.
davecoloradosprings
colorado
Posted: 06/09/21 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Thanks capacitor. How do I trip the GFCI? I have tried pushing the reset button as well as the test button. Is there a way that I can tell if the GFCI outlet is still good?
capacitor
California
Posted: 06/09/21 09:25am Link  |  Quote  |  Print  |  Notify Moderator
The test button will trip the GFI when breaker is on.
davecoloradosprings
colorado
Posted: 06/09/21 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Thanks capacitor. I will try that and post back results
philh
Belleville MI
Posted: 06/09/21 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
I'd go to there's a direct short. Breaker immediately "pops".
Bob Landry
Austin, texas
Posted: 06/09/21 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
Fuses have nothing to do with 115V power.
GFIs will not reset if there is no voltage to them.
Circuit breakers can and do go bad.
To reset a C/B you have to push it all the way off and then push it on.
Test the breaker by swapping it ith one of the others in the panel.
2011 Keystone Outback 277RL
Posted: 06/09/21 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
If the test button trips the GFCI when the breaker is ON the GICI is working
If the breaker is a Trip-o-matic then either there is a short (hot to neutral) over load (Too much stuff plugged in) or the breker is bad
Some breakers are designed to trip if you touch them.
UNPLUG everything. see if the breaker holds. then start plugging stuff back in one item at a time.
True story
Camper (Nice Class A) half his outlets were out.
I ask if he had an inverter (he did not know
Had a nice Tripp-Lite
Viewed from above the breakers looked like this \/ Made 'em look like this // and all was good.
