Twistedlarch
Cottage Grove, OR.
Hi, we just upgraded our TT from a 21' to a 28', we currently have a 2000 (1800 running) Yamaha inverter generator. I have a feeling that this little gennie won't supply enough power to run the new bigger trailer, what wattage would be recommended for the larger trailer?
Thanks
Brian
Boon Docker
What are you going to be running that you were not running with the smaller trailer?
Near Bishop, California
If you aren’t running the air conditioner, your generator will be just fine. Solar is easier but old generator will do it.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
time2roll
600 watts on the roof
675w Solar pictures back up
...and adequate batteries, time.
Still run into RVers who think solar doesn’t really work.
Twistedlarch
Cottage Grove, OR.
Boon Docker wrote: What are you going to be running that you were not running with the smaller trailer?
I want to be able to run everything, my little 2K would'nt run the AC in our little trailer.
Twistedlarch
Cottage Grove, OR.
time2roll wrote: 600 watts on the roof ![wink [emoticon]](http://www.rv.net/sharedcontent/cfb/images/wink.gif)
I put 400 watts on my little trailer, gonna miss it! I do plan to eventually run Solar on the new trailer.
valhalla360
No paticular place.
Twistedlarch wrote: Boon Docker wrote: What are you going to be running that you were not running with the smaller trailer?
Really no difference based on trailer size. The power demands are going to be about the same until you move up to dual air/con RVs.
You can jump thru some hoops spend some money and maybe get the 2000 to run the air/con.
I would recommend something in the 3000-3600w range. That's generally going to be plenty to get the air/con started and not be crazy big.
Keep an eye out for sales. Last year found a Champion Dual Fuel 3200w for $650 for some friends.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
enblethen
Moses Lake, WA
Verify the new rig's AC unit. Some newer ones do not require as much power as older ones.
Yes, a 3000-3500 genset will run everything.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Boon Docker
A good ole reliable Champion 3500 would work for you and not break the bank.
