pianotuna
Regina, SK, Canada
Unless you wish to run the air conditioner there is no need to upgrade the generator.
Regards, Don
Twistedlarch
Cottage Grove, OR.
Thanks everyone!
canoe on top
Denver, CO, US
With an Easy Start you might be able to run your AC with the generator you have. Cheaper than a new generator.
Twistedlarch
Cottage Grove, OR.
Here's my idea, currently I have the Yamaha SC2000i generator (2000 starting 1600 running). I can get another SC2000i for $500 and run them in parallel.
I can save myself about $500, I still have a very quiet set up, can only run one when I don't need the extra power, etc...
Does anyone else run small gennies in parallel?
Thanks
Brian
Twistedlarch wrote: Here's my idea, currently I have the Yamaha SC2000i generator (2000 starting 1600 running). I can get another SC2000i for $500 and run them in parallel.
Thanks
Brian
FWIW, you're not talking about a Yamaha generator, but rather a cheap knockoff. Just a bit misleading is all. Some of them work good, have had several (at work) that someone thought would be a great deal, that don't put out the advertised power or longevity of a real Yami or Honda.
That said, I agree that paralleling another 2000 is potentially a good choice especially for mobility of units, and a bit more power than the 3xxxW gennys.
2017 Heartland Torque T29
pianotuna
Regina, SK, Canada
Brian,
Many folks do that. I'm old as dirt now--so I prefer electric start on my genny.
For a very similar price, you could get the Predator 3500 inverter generator (with electric start).
Atlee
Mechanicsville, VA
I do, and all my friends who I tailgate with run 2 Honda's or Champions in parallel. If we need air, we run both, if we don't need air, we just run one.
Thanks
Brian
Erroll, Mary
2021 Coachmen Freedom Express 20SE
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
Equal-i-zer Hitch
Baja Man
Inland Empire, CA
I agree that since you want to run everything a 3000+Watt genny will be needed.
What are your thoughts on a dual fuel and mount above propane tanks using a Stromberg-Carlson mount? No gas to deal with, no fouled carbs, electric start !!!
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
kfp673
PA
Twistedlarch wrote: Boon Docker wrote: What are you going to be running that you were not running with the smaller trailer?
I want to be able to run everything, my little 2K would'nt run the AC in our little trailer.
Just get another of the same and a parallel kit. Save you lot's of money and back problems from lifting a 100lb generator. Plus, for the days when AC is not needed you can run a single. I went this way with Champions and super happy I did. Very easy to get them in and out of the truck and run everything in our camper
^ That’s where my head is at if you already have 1 - 2k genset.
Maybe a used Honda if budget is a concern.
But everything is a compromise with RVs. What you gain in lightweight easy to move and versatile you kinda lose in convienence having to fire up 2 Gennys and hook them together.
But can’t manhandle a 3k unit very easily and harder to store.
