I would recommend the larger 15K... The reason for this is that no matter how hot it is now it's getting hotter and hotter and hotter every year over the last several years has set records for "hottest on record" and you will be needing the added cool.
kfp673
PA
Thanks all! The unit is pre-wired for electric but not ducting. Should have mentioned that originally. So it would be a direct vent for the second. We have a front bathroom which currently has a vent and the bedroom has a vent. The factory vents can only be aimed not closed. So I intend to replace those with vents that can be closed helping cool the main living space and the bunk room more and then open all when we are on 30amp and can only run a single. Most of our camping is <90 F but being east coast it is often very humid. Anyway, sounds like most would for 15k for the bedroom. Maybe I add a box fan during the day to blow bedroom air out into the living space to help.
Thanks again all!
Super_Dave
Harrisville, UT
kfp673 wrote: Thanks all! The unit is pre-wired for electric but not ducting. Should have mentioned that originally. So it would be a direct vent for the second. We have a front bathroom which currently has a vent and the bedroom has a vent. The factory vents can only be aimed not closed. So I intend to replace those with vents that can be closed helping cool the main living space and the bunk room more and then open all when we are on 30amp and can only run a single. Most of our camping is <90 F but being east coast it is often very humid. Anyway, sounds like most would for 15k for the bedroom. Maybe I add a box fan during the day to blow bedroom air out into the living space to help.
Thanks again all!
If it is just for the bedroom, a polar cub 9 or 11 would be more than enough and possibly quiet enough to sleep with while running.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
Super_Dave
Harrisville, UT
P.S. - a big unit for a small space equals a lot of short cycles which isn't good.
valhalla360
No paticular place.
wanderingaimlessly wrote: The only thing I would question over the "bigger is better" folks is, how do you camp? If you frequently dry camp, you may find that a supplemental 9k to 11k btuh unit may allow you to run a little 2000 watt genny to power the slightly smaller ac unit on those occasions you dont have a shore power tap available.
You aren't running 2 air/con units off a 2000 generator.
If you plan to run the air/con off grid, better to jump up to a 3000w generator.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
valhalla360
No paticular place.
Super_Dave wrote: If it is just for the bedroom, a polar cub 9 or 11 would be more than enough and possibly quiet enough to sleep with while running.
Is there something wrong with your air/con? We've always slept with it on. Much easier than sleeping in a pool of sweat.
As far as short cycling...if that happens, just open the bedroom door, so the excess bleeds out extending the cycles.
Lantley
Ellicott City, Maryland
valhalla360 wrote: wanderingaimlessly wrote: The only thing I would question over the "bigger is better" folks is, how do you camp? If you frequently dry camp, you may find that a supplemental 9k to 11k btuh unit may allow you to run a little 2000 watt genny to power the slightly smaller ac unit on those occasions you dont have a shore power tap available.
When off grid 1 A/C may due. Having a lower wattage unit will have an advantage when power is coming from a smaller genset.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
wanderingaimlessly
Buggs Island lake
No, I'm not suggesting running two AC units off of a 2000 watt genny, but you can run a single little 9000 btuh AC on the small genny, which is not normally doable with the 15000 unit.
valhalla360
No paticular place.
wanderingaimlessly wrote: valhalla360 wrote: wanderingaimlessly wrote: The only thing I would question over the "bigger is better" folks is, how do you camp? If you frequently dry camp, you may find that a supplemental 9k to 11k btuh unit may allow you to run a little 2000 watt genny to power the slightly smaller ac unit on those occasions you dont have a shore power tap available.
Still better to jump up to a suitable generator (up around 3000w) but a 2000w can usually work if you use a soft start and make sure nothing else is running...but that applies even if you put in a small air/con. It's the startup load that is the challenge for undersized generators.
jdc1
Rescue, Ca
I take it you have a 50A connection? Running 2 AC's on 30A...Hmmmm.... Start there. You may need to consider a slow start capacitor installed on both units if you have 30A connection.
