kfp673
PA
We have a 37' travel trailer. For travel trailers and 5th wheels in the 35-40' range, I am curious if most of the second AC units (Bedroom units) are 13.5k or if people opt for the larger 15k. We are pre-wired and looking to add the second soon. Considering we have been living with the single for 4 seasons I suspect the 13.5k will be plenty and possibly a tad quieter, but I'd like to hear from those who have added it and which way you went. Thanks!
FrankoToo
New Braunfels, TX
Both our prior 40 ft. 5th wheel and our current 27 ft. TT have/had dual ACs. In both, the front or bedroom AC is/was 13.5k. If you're having it added, you could go with 15k but probably overkill for the space. Quieter? Because the space is smaller and it is right over your head, I would say not really.
FrankoToo
2018 Cruiser Stryker ST2313
2011 Ford F450 6.7L PS 4X4 Crew Cab Lariat
Acampingwewillgo
Seems to me for the difference in price, why not have more than what you might need. You can always run it on low fan. Living in So. Cal it would be a no brainer for me but on the east coast?? Maybe/maybe not!
I guess I'd still say " to big"....
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund.
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie, Mollie, Elvis, Potter and Rosie Love You! (40+ years in all)
Sandia Man
Rio Rancho, NM
Does your rig have a ducted system that the rear bedroom AC ties into, if so a 15K unit might be more advantageous than the 13K unit as it could assist the living area AC on hotter days. Without ducting a 13K unit along with the dump feature should cool down most RV bedroom areas quite nicely. We don't ever turn our AC units off on very hot days, don't want them to have to remove heat from rig all over again
We have large opposing slides and lots of windows in our main living area, often times the rear AC is set to deliver it's frigid air into the ducting system to support main AC on those blistering days of the year. Survived 110+ degree weather in TX & AZ on dozens of occasions, our AC units endure heavy usage and are also utilized in fan only mode to provide white noise for sleeping.
valhalla360
No paticular place.
For a negligible cost difference get the bigger unit.
Noise level is unlikely to be any different.
But if you wind up camping in 100F, I'd rather have too much than too little.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Super_Dave
Harrisville, UT
Per Sandia, the 15k will also dump into the living space which the single unit rarely can keep up with. FWIW, no unit is quiet enough to sleep with unless you sleep with shooters ear protection.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
C.B.
APPLETON WI USA
Added second air on top of bedroom. Tied into the duct system.
Went with the 15K over 13.5K for nickels and dimes more.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
Owens River area
Pick the one that is quietest. Both will cool the bedroom.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
ford truck guy
Pennsylvania
My last Redwood had 2 @ 15k and it was nice.. the only issue was that when really hot out, with it being 42’, it would be hard to keep up with the heat in n full sun in summer. When in doubt, go with the bigger, you won’t be sorry...
Now, my newer Redwood has 3 @ 15k.. that’s freaking awesome in full sun in summer heat
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
wanderingaimlessly
Buggs Island lake
The only thing I would question over the "bigger is better" folks is, how do you camp? If you frequently dry camp, you may find that a supplemental 9k to 11k btuh unit may allow you to run a little 2000 watt genny to power the slightly smaller ac unit on those occasions you dont have a shore power tap available.
