RV.Net Open Roads Forum: Truck Campers: Nor Cold 2 way??
 > Nor Cold 2 way??
ADA6969
SPARKS,NV
Posted: 06/10/21 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Hello All,
Just got back from trip with new 2021 A/F 1150 19 DAYS. Temps were 27 degrees to over 100 out side.
Fridge was leveled. ON 110v pugged in worked correct. On propane fridge was 50-60 degrees freezer was 0-10
On generator all night and day Fridge 35-55 freezer 0-10
Put fan in fridge no difference.
No matter what outside temp was on propane fridge ran hot.
Any help please?
2012 RAM 3500DRW MAX TOW 4WD AUTO STD CAB ST DIESEL STABLE LOADS AIR BAGS AND RS9000XLS, ROADMASTER 1 3/8" REAR SWAY BAR 2021 AF 1150 DRY BATH TOWING 2017 JEEP RUBICON JKU BUILT. OR 2020 JEEP RUBICON JL BUILT
Geo*Boy
Unknown
Posted: 06/10/21 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Andy, go to ARPRV.com and purchase and install the #4 kit with dual fans and you fridge will run perfectly. My fridge in my AF 990 did exactly the same and after the install I run my fridge on setting 6 and the beer is cold and ice cream hard.
Old-Biscuit
Verde Valley
Posted: 06/10/21 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Works on AC but not on propane
AO airflow/draft is sufficient for removal of heat
AC Element and Propane transfer roughly the same heat energy to boil the ammonia coolant into a vapor
SO
Dirty Burner assembly
OR LP System Pressure is Low (S/B 11"WC --0.4psi. IF low the flame temp will be low and heat generated will not boil the ammonia in sufficient volume to absorb heat from food compartment)
**10"WC is 0.36 psi....can not visually tell difference between 11"WC and 10"WC. Need a manometer to measure system pressure...with at least 50% of appliances in service
US NAVY------USS Decatur DDG31
Geo*Boy
Unknown
Posted: 06/10/21 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
SO
Hard to believe that the burner is dirty already, but a good thing to check.
If he is traveling, unit is on propane. Side venting refrigerator when traveling are terribly inefficient. ARPRV fixed my inefficient fridge.
brholt
Seattle
Posted: 06/10/21 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
SO
+1
Had pretty much the same experience with our 1150 one time. Worked on AC, Fridge warm on propane. Looked at the burner and you could see it was noticeably smaller then normal. Was going to take it apart to clean the next day but it was working. Looked at the flame and it was burning brightly
ADA6969
SPARKS,NV
Posted: 06/10/21 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
All was clean. Brand new unit. geo boy, will look into this, thanks
I was pluged in with in 1 hour went from 58 deg on max 5 to 29 deg on #5 moved it to 3 stayed at 34-38 deg
ADA6969
SPARKS,NV
Posted: 06/10/21 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
Remember he freezer works fine on LP, Or 110
Old-Biscuit
Verde Valley
Posted: 06/10/21 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
Freezer is FIRST in the cooling process
Freezer gets cold then food compartment can start cooling PROVIDED sufficient ammonia is being boiled into vapor
See the Hot vapor condenses into liquid as it flows thru Condenser at top of frduge
Then when it interacts with the Hydrogen Gas it becomes super cold which then absorbs the heat thru the Freezer EVAP Coil and then onto food compartment Evap Coil
IF NOT enough ammonia is boiled into vapor then not enough vapor condenses into liquid then not enough COLD liquid is available to absorb heat from BOTH compartments
Dirty Burner/Orifice....spide webs etc WILL disrupt the air/fuel mixture resulting in poor flame temps
LOW LP System Pressure will directly result in low flame temps
Low flame temps...flue baffle will NOT transfer sufficient heat to boil ammonia in volume needed to absorb heat.
AC Element is hot enough ...cooling unit is functional
Propane flame...not hot enough
#1Flyboy
California
Posted: 06/10/21 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
We’re FT, I blow out the burner & chimney at least 2 times a year; preventative maintenance….
bighatnohorse
Gig Harbor - Cave Creek
Posted: 06/11/21 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Does the dual fan kit run quieter than the original fan or about the same?
 > Nor Cold 2 way??
