RV.Net Open Roads Forum: Tech Issues: Screws backing out
 > Screws backing out
lenr
Indianapolis, IN
Posted: 06/10/21 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
The screws in the trim strip at the top of the sides of our trailer are backing out. The strip covers the rubber roof where it wraps around the edge and reaches down the side about 2". I presume that these screws go into wood roof framing. Some screws are actually pushing the plastic covering strip out of place. I found about half of them stripped such that they're hardly holding themselves in. What material could I squirt into the holes before putting the screw back in that would help hold them in place?
2oldman
So Cal
Posted: 06/10/21 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
glue
capacitor
California
Posted: 06/10/21 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
And a bit larger screw.
QCMan
Independent Republic of Horry
Posted: 06/10/21 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
And toothpicks!
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
monkey44
Cape Cod, MA and Central Fla
Posted: 06/10/21 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
All three above ... stick glue and toothpicks, let dry completely. Then a slightly larger screw. Be careful the screw is one size fatter but not longer.
Another method. IF easy access, remove screw, drill slightly larger hole, then glue and punch in a hardwood dowel - a tight fit. Then drill pilot hole and a new screw.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
Seon
Lake Camanche, CA
3m 5200 and the screw will be in there forever.
lenr
Indianapolis, IN
Posted: 06/10/21 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Wood glue?
Thought about Hard as nails, but wondered if it would be too hard, especially if the screws needed to be removed someday. Also, though of silicone, except maybe it's too soft. I haven't had time to check out larger screws. Toothpicks were suggested by my wood worker son, but I've probably got a hundred screws to strengthen--that's a lot of toothpicks!
Anza-Borrego Desert SP area
Posted: 06/10/21 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Glue and toothpicks have been serving me well for many years.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
monkey44
Posted: 06/10/21 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, lots of toothpicks. But: Like the clique says -- Take your time and do it right once. Or, hurry and do it twice.
DrewE
Vermont
Posted: 06/10/21 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
If you replace the screws, give strong consideration to using stainless ones.
