RV.Net Open Roads Forum: Tow Vehicles: Trailer brake warning on RAM
Search only in Tow Vehicles
 > Trailer brake warning on RAM
Flashman
Tucson, Aizona, USA
Posted: 06/10/21 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2017 3500 and I get a check trailer brake warning when hooked up to my 5th wheel. I put another truck on the trailer and got the same warning. So the problem is in the trailer.
How does the truck know that the connection is not good? I thought the wire from the truck was an out put voltage. The lights (brake turn signal) on the trailer work fine.
Fisherman
Angus, Ontario, Canada
Posted: 06/10/21 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
If the circuit to the trailer brakes is not complete, it will sense that and send the error message. If both trucks are giving the same result, lights work but brakes send a message, check to see that the break away cable and switch are working. Then do a continuity check of the trailer brake wires, from the 7 pin connector. Could be as simple as a broken off ground or power wire.
Anza-Borrego Desert SP area
Posted: 06/10/21 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Consider cleaning your 7 pin connector. I decided to replace my OE connector and no problems since.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Learjet
Louisiana
Posted: 06/10/21 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
is it set to the proper setting in the menu...Electric brakes or EOH (Electric over Hydraulics)
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
eHoefler
ozark mountains
Posted: 06/11/21 05:44am Link  |  Quote  |  Print  |  Notify Moderator
I will sense an open circuit and a shorted circuit
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
SweetLou
La Quinta, CA USA
Posted: 06/11/21 07:35am Link  |  Quote  |  Print  |  Notify Moderator
X2
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
Flashman
Tucson, Aizona, USA
Posted: 06/11/21 08:22am Link  |  Quote  |  Print  |  Notify Moderator
All exposed wires are good - its the buried ones that suck.
kellem
Shenandoah valley,VA
Posted: 06/11/21 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Put some dielectric grease on the 7-pin connection, start simple.
Thermoguy
Graham, WA
Posted: 06/11/21 09:08am Link  |  Quote  |  Print  |  Notify Moderator
This worked for me as well.
Flashman
Tucson, Aizona, USA
Posted: 06/11/21 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Didn't use the grease but sprayed with cleaner. Remember a 2nd truck showed same problem.
