RV.Net Open Roads Forum: Tech Issues: Dometic 4 door rv fridge ice buildup
 > Dometic 4 door rv fridge ice buildup
MPI_Mallard
Morpeth Ontario,St. Cloud Florida
Posted: 06/11/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
I have a 4 door dometic 2-way fridge and it ice's up regularly, I checked the seals and they are good,, any ideas?
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blücher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
Posted: 06/11/21 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
You might shut off the ice maker and switch to a small countertop ice maker, More ice, faster, and no release of moisture into the freezer.
Your "Frost Free' unit at home actually has a HEATER to melt the ice
But the RV Absorption unit does not.
I found when my Ice Maker failed...... The unit did not ice up nearly as much after I removed it and went to a counter top.
dougrainer
Carrolton, Texas
Posted: 06/11/21 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
How LONG does it take to ice up? Are you talking Freezer or BOTH? Doug
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 06/11/21 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
We generally had to defrost every few months during full time use.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
MPI_Mallard
Posted: 06/13/21 08:54am Link  |  Quote  |  Print  |  Notify Moderator
No icemaker (except for Frau Blücher) it collects about a 1/2" of snowy ice on the back wall of the freezer an the aluminum fins inside the fridge,,
wolfe10
Posted: 06/13/21 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Do the "dollar bill test" of both refrigerator and freezer gaskets. Should be reasonable resistance to pulling out the bill all the way around.
Verify that the refrigerator condensate drain either has a drip loop in it or a restrictor in the end. If neither, warm outside air will rise into the refrigerator.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
