RV.Net Open Roads Forum: Tech Issues: Help with Suburban Hot Water Heater.
 > Help with Suburban Hot Water Heater.
1ed
Northern California
Posted: 06/11/21 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2020 Rockwood Mini Lite 2109S. This past week went to the Sierra's at an elevation of about 6500 ft. The Hot Water heater would not work on propane and I tried everything. Finally had to use the electric side and had hot water. Looked at the manual and it states that the propane will only work at 4500 ft or lower and I would have to have it derated. Has anyone done this and if so how do you do it? The older style had a adjustment at the tube but this one does not. As soon as I got home to an elevation of 1500 ft I tried the hot water heater and she fired up in a second. So I need some help. Thanks Ed
Also, the oven would not lite. all the burners worked, the heater worked and I just had the tanks filled with propane. Are these related?
model on hot water heater is SW6DELC don't have one for the stove.
enblethen
Moses Lake, WA
Posted: 06/12/21 06:40am Link  |  Quote  |  Print  |  Notify Moderator
I am thinking it is a pressure problem. Possible weak regulator.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Old-Biscuit
Verde Valley
Posted: 06/12/21 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Air/fuel ratio was out of range....
Not a Main Regulator issue but a 'fuel' issue at the appliance
Due to high altitudes....less dense air therefore the mixture is fuel rich
Derating is done by changing of Orifices to small size (larger number)
Next time at altitude ..try running water heater with panel fully open
That will sometimes allow more air for combustion
Atwood Models have the air shutter for adjustments
Suburban does not
FYI: Suburban SW6DELC is a 6 gal Direct Spark Ignition with 12VDC Relay for 120VAC Element and uses a Cord to plug into an outlet
US NAVY------USS Decatur DDG31
