RV.Net Open Roads Forum: F53 Rear Sway Bar Bushings: Wrong Size
 > F53 Rear Sway Bar Bushings: Wrong Size
FloridaRosebud
Melbourne
Posted: 06/12/21 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
RedRollingRoadblock wrote:
E-Bay seller skuterdude makes and sells quality replacement bushings. Contact him and give him your measurements.
Yep, agree. I bought mine from him, and he is very knowledgable and helpful. Cost is minimal as well.
Al
georgelesley
Tennessee
Posted: 06/13/21 05:14am Link  |  Quote  |  Print  |  Notify Moderator
Be sure to use blue locktite on the bracket mounting bolts, the bolts often come loose otherwise. This is a very well known problem and torque the bolts to 66lbs when installing. There is a long thread on IRV2 Ford forum about this exact subject.
George & Lesley
2014 Itasca Sunova 33C, 2019 Jeep Cherokee Lattitude Plus toad, Demco/SMI towing system
Sastma
AZ
Posted: 06/14/21 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the tips.
I got a real good fit after compressing the brackets. You might notice these brackets are pretty sturdy compared to the stock. In all the existing bushings are in really good shape, they were just about 1 mm to wide.
