RV.Net Open Roads Forum: Around the Campfire: Electrical type question
 > Electrical type question
Tinstar
McKinney, TX
Posted: 06/13/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
At my sticks and bricks, I have to replace a pool pump.
Which is more efficient to run (uses less electricity), a 2.5 HP pump drawing 6.3 amps or a 1 HP pump drawing 8 amps? They are both 120 volt. From what I can tell, the 2.5 HP is around 1800 watts and the 1 HP is around 750 watts. It just doesn't make sense to me that the 2.5 has lower amps and thus the reason for my question.
Thanks for any insight.
* This post was edited 06/13/21 09:50am by Tinstar *
">Never pass up a chance to go somewhere">
cougar28
Lowell,AR USA
Posted: 06/13/21 11:11am Link  |  Quote  |  Print  |  Notify Moderator
I've sold and repaired thousand's in the course of 30 + years. Something is not right about those numbers. I've never seen a 2.5hp that was capable of being run on 115v or a 2hp for that matter. Is this a above ground pool?
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
Tinstar
McKinney, TX
Posted: 06/13/21 11:15am Link  |  Quote  |  Print  |  Notify Moderator
I don't know. Here's what the ad says.
Clickey
DrewE
Vermont
Posted: 06/13/21 11:36am Link  |  Quote  |  Print  |  Notify Moderator
There must be an error in the listing's specifications. 120V * 6.3A = 756W or about 1 HP. Somebody copied a wrong number somewhere. The AliExpress listing shows the same electrical specifications, but also a plug that is decidedly not a 120V plug (or at least one that I've ever seen).
In terms of electrical energy use, the actual power used will depend on the (mechanical) load on the pump, which in turn is determined by the sizes and lengths and arrangement of the pipes or hoses to and from the pump, the inlets and outlets in the pool, the speed and pressure of the water flow, the design of the pump itself, and probably a few other variables. I would not expect vast differences in overall efficiency assuming a similar flow rate; just because a motor is rated for 2.5 HP doesn't mean that it is always producing that amount of power, nor consuming the same amount of input power. In general, all other things being equal and assuming the power specifications are not inflated beyond all reason, the larger pump would pump water at a higher flow rate (and hence pressure), which means greater circulation but a little more loss due to friction, and so I'd expect it to be a little less efficient in practice (but give faster filtering/circulation).
Tinstar
McKinney, TX
Posted: 06/13/21 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
That's for the help guys. I ended up ordering a 1.5 HP name brand pump made more for my pool instead of the 2.5 HP on that has a confusing description.
