RV.Net Open Roads Forum: What's the best way to get RV anti-freeze out of system.
 > What's the best way to get RV anti-freeze out of system.
Yosemite Sam1
Under the pines.
Posted: 06/14/21 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
I turned on all the faucets and water outlets after filling up the fresh water tank and then run the water pump.
I also connect the municipal water supply line.
Killed a few grasses on my lawn with some spillage.[emoticon]
Too much work with anti-freeze for this lazy as$ while compressed air is such a simple process and worth the investment in entry-level Craftsman air compressor.
Sjm9911
New Jersey
Posted: 06/14/21 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
I go faucet by faucet, and then do the bottem drains last. I do not open them all at once. I start closest to the pump and work out.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
ferndaleflyer
everywhere
Posted: 06/14/21 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
I don't winterize, just keep heat on and hot water heater on
pianotuna
Regina, SK, Canada
Posted: 06/14/21 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting. I do the opposite order starting farthest from the pump, but open only one at a time.
I blow
install pink
blow again saving what I can.
Regards, Don
Sjm9911
New Jersey
Posted: 06/14/21 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
I think its the one by one that does it. That way it clears that line, and the back pressure prevents the antifreeze from moving around in the system.
philh
Belleville MI
Posted: 06/14/21 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Mine trapped pink stuff leading to hot water tank. That trapped pink stuff contaminated the system until it finally flushed it out. In retrospect, I should have left the hot water tank drain valve out and flushed that trapped pink stuff.
docsouce
Seekonk Ma.
Posted: 06/14/21 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Is there an on board water filter that might be holding some anti freeze? Just a thought.....
2020 JAYCO 26XD
Just right for the two of us!
LouLawrence
Traveling the US!
Posted: 06/14/21 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Don't use anti-freeze next time. Drain the fresh water tank, and black and grey tanks. Use an air compressor to blow the fresh water lines and then just throw a bit of anti-freeze in the P-traps to get rid of or dilute the water enough to prevent freezing. Next year you are good to go by just filling the tanks and heading down the road.
JimK-NY
NY
Posted: 06/14/21 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Something is wrong. It has never taken me more than a few gallons of water and a couple of minutes to completely remove the antifreeze. Best guess is there is antifreeze in the hot water or main water tank. Any antifreeze in the lines or faucets should rinse out quickly.
Sjm9911
New Jersey
Posted: 06/14/21 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
I had another guy sware by this , untill his water pump broke. It depends on the climate your in. And while blowing out will work 90 percent of the time, its the other 10 percent that gets ya.
