RV.Net Open Roads Forum: Tow Vehicles: trailer brake issue
Search only in Tow Vehicles
 > trailer brake issue
walker111
se calgary
Posted: 06/14/21 08:41am Link  |  Quote  |  Print  |  Notify Moderator
2017 f350 diesel and 2014 voltage 3305 toyhauler.
I am getting a prompt on my screen when hooked up and I pull the brake controller it shows TRAILER DISCONECTED.
Any ideas? Bought some diaelctric grease and will apply some and was thinking maybe a ground issue??
Thanks
guidry
Texas Cajun
Posted: 06/14/21 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Check your ground first then move to other wires. Something may have hit some wires near the wheels or loosened one.
azdryheat
Tucson, AZ
Posted: 06/14/21 09:36am Link  |  Quote  |  Print  |  Notify Moderator
My "trailer disconnected" warning shows up when the trailer umbilical cord looses contact with the truck receptacle.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
WNYBob
Tonawanda, NY
Posted: 06/14/21 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Don't use dielectric grease!
Use contact cleaner / lube.
walker111
se calgary
Posted: 06/14/21 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for replies
Will look into it after work
Beaker
Brevard, NC
Posted: 06/14/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
jdc1
Rescue, Ca
Posted: 06/14/21 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Sometimes the connector gets a little wore out. You have to expand the connections a little so they are tighter (or replace the ends).
walker111
se calgary
Posted: 06/29/21 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
Picked trailer up to tow home for a trip in a few days. Blew air through pig tails and cleaned them up and did add some grease.
Read about choosing electric over the electric over hydraulic option through the settings screen. Tried that and still see trailer disconnected?????
Then I switch to electric over hydraulic and it shows connected and gain setting at 10 and there is braking but it is poor.
Looking that I need to check the wires at the wheels under trailer. All original and probably dirty and corroded.
38 degrees C here
Don't feel like getting under trailer at all right now!!!
Have a few days prior to trip so will check tomorrow when it is cooler in the AM.
BenK
SF BayArea
Posted: 06/29/21 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
Most all of the similar problems helped others with…ended up with the trailer wiring.
Most common was the harness to the drum brake.
2nd most is the routing and some trailer OEMs uses daisy-chain.
After unplugging & cleaning contacts & applying dia electric grease most were better.
Best has been to retire the trailer with dedicated runs from each wheel brake directly to a central point by the coupler.
If you go that route, increase the wire gauge and only use ringlugs…NEVER tap connectors (they were invented for telephone use…a static application)
-Ben Picture of my rig
Flashman
Tucson, Aizona, USA
Posted: 06/29/21 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
This was happening to me and I simply cleaned and re-bent the contacts from trailer to truck connection and problem fixed
