RV.Net Open Roads Forum: 1/2" h x 1/4" w Window Edge Weather Stripping
 > 1/2" h x 1/4" w Window Edge Weather Stripping
Sastma
AZ
Posted: 06/14/21 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Hey guys,
Continuing with the RV fixes and noticed many of my window's weather stripping has shrunk and needs to be replaced.
I found a source on Amazon seems to be the best price at $127 for 30 feet. Any other good sources suggestions?
Looking at all the windows I estimate I need probably twice that much to replace everything.
I'm in Phoenix... looking forward to 115 degrees or more this week [emoticon]
SKroamcampgrounds
New Orleans
Posted: 06/14/21 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
amazon is your best bet as far as prices go. although the self-adhesive weather stripping may be more expensive, its worth it if you have that much surface to cover. when you're removing the old weather stripping, use paint thinner and a putty scraper to remove the old adhesive. good luck!
craig7h
Branson MO area
Posted: 06/15/21 04:58am Link  |  Quote  |  Print  |  Notify Moderator
I have found these folks have most everything you need
https://www.steelerubber.com/
Itasca Meridian SE 36g
Road Master Tow Dolly
