RV.Net Open Roads Forum: Truck Campers: RE: Front hitch
 > RE: Front hitch
macdale4
Apopka, FL, USA
Posted: 06/14/21 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
How much weight would be too much weight on a Ford F-350 dually front hitch? It seems like too much weight would affect the suspension and steering.
Dale & Eileen
1998 Lance 945 Legend
2011 Ford F-350, dually, 4 X 4
Posted: 06/14/21 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Define “effect”. And does your camper unload the front axle at all?
Otherwise, a few hundred lbs will not even be noticeable.
I’d say the strength of the hitch receiver would come into play before the weight causing significant wear n tear.
A “good” hitch like a Curt is rated for 350lbs
2017 Heartland Torque T29
AnEv942
CA
Posted: 06/14/21 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
I believe most front hitches are rated @ vertical load of 500 lbs,
line pull ~9000 lbs.
Our camper projects page
brholt
Seattle
Posted: 06/14/21 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
My front hitch is rated at 1,000 lbs tongue weight and 10,000 pounds towing.
Front hitch
Buzzcut1
Norcal
Posted: 06/14/21 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
compared to how much weight the TC in the back lightens the front axle? Adding up to 500 up front like the above poster listed is going to improve steering not make it worse
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Sagebrush
Jacksonville AL
Posted: 06/14/21 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
A few hundred pounds won't do much. Guys hang snow plows off stock trucks all the time. I have a Ranch Hand bumper on my 3500 with stock springs, anymore weight and I would be adding 2" or 3" lift HD coils. You can get HD springs to solve the sagging issue for just about anything.
https://www.sdtrucksprings.com/index.php........1&zenid=6b259387b176a1bcb8f3c48227f63826
Kayteg1
California > Nevada
Posted: 06/14/21 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
Had front hitches on almost all of my F-series trucks.
The older truck had hitches mounted on front bumper mounts, when 2017 model has hitch bolted to the lower frame.
Loved the last one as carrying Honda 3000 on the hitch, it did not cover radiator too much.
As members above pointed -bigger TC are taking weigh off front axle, so putting the weigh there improves stabilization.
StirCrazy
Kamloops, BC, Canada
Posted: 06/15/21 06:33am Link  |  Quote  |  Print  |  Notify Moderator
I dont have a dually, but with my camper on my front axel weighs 5093 lbs and the total capacity for the front axel is 5600 lbs so that means I could put 500lbs on it at most.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
mkirsch
Rochester, NY
Posted: 06/15/21 06:39am Link  |  Quote  |  Print  |  Notify Moderator
If you're that worried about it take the rig to the scales and get it weighed so you can see how much capacity you've got left to work with.
Kayteg1
California > Nevada
Posted: 06/15/21 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Steve
500 lb on front hitch will add about 600 lb on front axle.
Might be even more, depends on configuration.
* This post was edited 06/15/21 09:10am by Kayteg1 *
 > RE: Front hitch
