RV.Net Open Roads Forum: Travel Trailers: Running a fridge on propane?
 > Running a fridge on propane?
DinTulsa
Tulsa
Posted: 06/15/21 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Roughly how long can I run a fridge on propane in 90 degree heat? I’m camping at a site that has 30amp only so I’m wanting to run my fridge on propane. Will a 20lb cylinder normally last 4 days?
Ed_Gee
Central Oregon coast
Posted: 06/15/21 10:45am Link  |  Quote  |  Print  |  Notify Moderator
My three way fridge draws 2.5 Amps when it is in cooling cycle. I wouldn't think that will have much impact on your 30A shore power consumption. My experience with fridge on LPG mode is that it will run for weeks .... propane usage is quite low.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
Boon Docker
Posted: 06/15/21 10:54am Link  |  Quote  |  Print  |  Notify Moderator
You will be good for many more days that just 4 days, more like weeks.
Sandia Man
Rio Rancho, NM
Posted: 06/15/21 10:58am Link  |  Quote  |  Print  |  Notify Moderator
With a full propane tank your fridge on LP mode will go quite a while, 4 days should be no problem. Our 4 door RV fridge consumes roughly 4 amps, if attempting to run both ACs on 30 Amps those few amps to power fridge could put you just over 30 amps, in that situation we have WH and fridge set to propane.
Jim2007
Greeley, Colorado
Posted: 06/15/21 11:01am Link  |  Quote  |  Print  |  Notify Moderator
I agree with Ed and Boon. Jim2007
TV: 2016 Dodge 2500 Diesel
Rig: 2013 Heartland, Sundance, 5th wheel
Old-Biscuit
Verde Valley
Posted: 06/15/21 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Large fridge 450W elements.....3.5A AC draw
Water heater 1400W element......11.5A AC draw
Propane has 91,500btu per gallon...20#/4.5gal cylinder----411,750btu available
Fridge would have roughly 1500btu per hour of run time
Water heater roughly 10,000 - 12,000btu per hour run time
Propane can feed those 2 appliances for LONG time.....weeks
US NAVY------USS Decatur DDG31
2oldman
NM
Posted: 06/15/21 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Long time. Less time if your fridge is on the pm sunny side.
DinTulsa
Tulsa
Posted: 06/15/21 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you! Am I understanding g so if you correctly that you can run both Ac units on a 30 amp, given you run the fridge and wh on propane?
dodge guy
Bartlett IL
Posted: 06/15/21 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Unless both have the soft start capacitors, no! You will only be able to run one.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
2oldman
NM
Posted: 06/15/21 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
It's iffy running both at the same time, plus you likely have a converter. I would pay very close attention to heat at your plug.
* This post was edited 06/15/21 03:25pm by 2oldman *
