RV.Net Open Roads Forum: Travel Trailers: Dehumidifier?
 > Dehumidifier?
alexey75
Nova Scotia
Posted: 06/15/21 10:59am Link  |  Quote  |  Print  |  Notify Moderator
Hello guys,
We’re pretty big family, every morning all windows covered with moisture.
I saw on Amazon there are a lot of small dehumidifiers, something like that:
Dehumidifiers
Does anyone have good experience with these small dehumidifiers?
This specific model probably not big enough for 28 ft trailer…
pianotuna
Regina, SK, Canada
Posted: 06/15/21 11:18am Link  |  Quote  |  Print  |  Notify Moderator
turn on some electric heat and open a roof vent.
Regards, Don
mobeewan
Hampton, Va
Posted: 06/15/21 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
The dehumidifier that you linked is only rated for 18 ounces per day. You'll need something more along the lines of 25 pints per day and that may only put a dent in it with a large family. An individual adult can exhale three pints of water while they sleep, part of the reason why you are thirsty when you wake up. Then there's showering and cooking which releases moisture into the air. I lived alone in my 28ft travel trailer for a while, using a 25 pint per day unit that I had to run continuously throughout winter. I showered once a day while running the ceiling vent and only used the microwave. The dehumidifier was barely adequate.
You might want to start looking at these dehumidifiers.
Huntindog
Phoenix AZ
Posted: 06/15/21 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
He can use the furnace without adding any moisture to the inside air. No need for electric heat, unless he just wants it for other reasons
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
ktmrfs
Portland, Oregon
Posted: 06/15/21 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
alexey75 wrote:
Hello guys,
Dehumidifiers
don't waist your money on those small units. You need one that can remove 5+ GALLONS of water/day. Get a smaller compressor based unit at a big box store, you will find it will fill up in a few hours, empty it and then it may go 12 hours or even a day.
next what introduces water into the air
1) people breathing..... more water than you think
2) stove/oven. they will dump about 1 gallon of water into the air for every gallon of propane burned
3) damp clothes
4) NON VENTED heaters, (not a furnace) same as stove or oven. A vented heater (propane furnace) introduces ZERO, NADA, not one drop of moisture into the air, all the combustion air goes outside. Same with the water heater
So once you have a dehumidifier running, when you shower or cook crack a roof vent. try to keep wet stuff out of the trailer.
We often camp on rainy days in oregon, even with 5 of us in the trailer with the dehumidifier running and reasonable use of oven, stove, showers etc. we can keep the RH down enough that windows stay clear.
2011 Keystone Outback 295RE
pianotuna
Regina, SK, Canada
Posted: 06/15/21 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
They rate dehumidifiers at 77 F. (25 c). When it is colder than that the collection of moisture is quite poor.
The reason for electric heat is to warm air coming into the rv from a window. We need to get the surfaces (temperature on surface above) the dew point.
fixed a typo. Thanks for pointing it out.
* This post was edited 06/26/21 08:48am by pianotuna *
ktmrfs
Portland, Oregon
Posted: 06/15/21 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
The reason for electric heat is to warm air coming into the rv from a window. We need to get the surfaces below the dew point.
Ours seems to do well even down to about 60F. below that it drops off pretty quick.
and yes, you want surfaces below the dew point, which in a trailer with single pane windows can be quite difficult!
bgum
South Louisiana
Posted: 06/15/21 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing beats a compressor dehumidifier. Having said that we run a small dehumidifier like the one you linked to. We use it in our 16 foot when stored. In this high temperature and humidity area it will fill in about 4 days. It is better than nothing and we have never been bothered by mold or mildew. With your load you will need a larger compressor style.
alexey75
Nova Scotia
Posted: 06/16/21 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys. We open the vents when we take a shower or cooking, but still, every morning all windows covered with water.
About dew point, does it mean the windows inside should be about 46-50F, right? Usually we keep the temperature inside about 70F.
I see in general the compressor dehumidifier are more louder than desiccant, no?
valhalla360
No paticular place.
Posted: 06/16/21 07:39am Link  |  Quote  |  Print  |  Notify Moderator
For most practical purposes, keeping the windows at or below the dew point is not very practical. We like it cold at night for sleeping and no it does work.
About the only way to do it would be to add an interior layer to mimic dual pained windows (kind of an interior storm window). But even there the frames will still tend build up moisture.
Drying out the air is really the solution for cold weather camping.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
 > Dehumidifier?
