RV.Net Open Roads Forum: Tow Vehicles: Wiper blades
Search only in Tow Vehicles
 > Wiper blades
Taxman2436
Holden, MA
Posted: 06/16/21 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2019 Ford F-250 that I purchased March 2020 and the original wiper blades would scrape and shudder in light rain so I replaced them and then replaced the replacements. I’m wondering if this is one of those windshields that are a problem for wiper blades. Any similar experiences or suggestions?
Lenny
Taxman2436
Holden,MA
2019 Ford F-250 6.7 L Diesel
2021 Salem Hemisphere
MFL
Midwest
Posted: 06/16/21 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
The wipers should function properly for several years, unless an obvious reason, such as sitting in extreme sunlight/heat continuously.
Another issue that will cause the wiper shudder you describe, is using hot wax treatment at the car wash. Try giving your windshield a good cleaning when replacing wipers, to avoid contaminates.
Jerry
Posted: 06/16/21 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Lenny
In owning and/or driving probably 100 different vehicles in the 30+ years I've had a drivers license, I cannot say I've ever heard of this phenomena.
What is it that makes a windshield a problem for wiper blades?
2017 Heartland Torque T29
Old-Biscuit
Verde Valley
Posted: 06/16/21 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Good cleaning....soap/water thoroughly rinsing and then squeegee dry or micofiber towel
Afterwards ...Apply Rain-X
*Follow cleaning/applying instructions on bottle!
Light rain...won't need wipers and when you do use them they will not shudder
Had that shudder issue when bought truck brand new in 2007
After using Rain-X...no more shudder---reapply yearly
**And trucks sits outside in AZ
US NAVY------USS Decatur DDG31
MFL
Midwest
Posted: 06/16/21 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Agree...after cleaning, apply Rain-X, excellent product!
Taxman2436
Holden, MA
Posted: 06/16/21 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you, good advice. I don’t get the wax at the car wash and am diligent about wiping the wiper blades with window cleaner from time to time. I’m going to try the Rainex. Thanks!
Wadcutter
IL
Posted: 06/16/21 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Mr Banks explains wiper blades in this link.
Wiper blades
Camped in every state
Hank85713
Tucson, Az
Posted: 06/16/21 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
I use dawn dish soap to clean the windshield followed by application of a silicon car polish. Cleans the crud better than anything else I have used. As to rainex its ok but the silicone I find is much better as it seems to fill the glass imperfections making it very smooth and lasts longer than the rainex.
The use of microfibre towels is also needed instead of just any rag, Tshirt etc. The microfibre towels also work well with the polish to apply then wipe down. Dirt-dust will be removed just by turning on the wipers without the spray and a damp rag is all it takes to clean the windshield again.
FYI I used the above on school bus windows for over 10 years, they stayed cleaner longer even in Az heat and dry.
FlatBroke
CO/AZ
Posted: 06/17/21 07:19am Link  |  Quote  |  Print  |  Notify Moderator
I use Protect all or 303 on the blades. Mine are outside all the time so they take a “set”. I just switch them from side to side a couple of times a year.
Hitch Hiker
"08" 29.5 FKTG LS
ACZL
UPstate,NY
Posted: 06/17/21 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Can't say as if I've ever had that problem on past 3 Fords. My current '17 which was built in late '16, had orig blades on it for couple years. Yes, I've also applied Rain -X but haven't been diligent about keeping up w/ it. On the other hand, current blades are Rain-X ones. No problems. OP, are you buying good quality blades?
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
 > Wiper blades
