RV.Net Open Roads Forum: Tech Issues: Grounding an MPPT controller
 > Grounding an MPPT controller
daveandaboat
32507
Posted: 06/16/21 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I'm in the process of installing solar for our 1181 Camper (2010). I'm using a Victron 100/30 MPPT controller along with the Victron BMV-712 monitor & shunt. We have 2 LifePo4 100ah batteries. No inverter yet, that will be added later.
I'm trying to figure out where to run the ground connection from the MPPT controller? I've got the neg battery out connection from the MPPT running to the 'load' side of the Shunt (I've seen it wired this way on several diagrams online). Would I also run the ground from the mppt to this connection as well? There is no negative bus bar near the batteries.
When I installed the shunt, there was a single post with 3 wires connected. One from the battery negative, one that runs to the Generator negative, and one that runs to the jack control board. I connected the battery negative to one side of the shunt and the other two to the 'load' side.
Can the 'load' side of the shunt serve as a ground for the MPPT? If not, what are my other options.
Appreciate any help.
-Dave
enblethen
Moses Lake, WA
Posted: 06/16/21 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Are you talking the negative connection? It should go to the battery or to the battery side of the shunt.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
FWC
The Wilderness
Posted: 06/16/21 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
The ground on the MPPT is not all that important in a mobile application, so it it fine to tie it to either side of the shunt, or to the battery negative, or to a negative bus, which ever is most convenient. No current will flow on this wire.
daveandaboat
32507
Posted: 06/17/21 04:38am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info FWC! Wasn't sure if there was a potential to create a ground loop or something that might cause problems. Much appreciated!!
MrWizard
Traveling
Posted: 06/18/21 04:11am Link  |  Quote  |  Print  |  Notify Moderator
I would connect solar controllers ground to the RV frame,
If I bothered to connect it at all,
I would Not connect it to battery shunt
Ground in this case is for lighting protection and would goto earth ground when used in a stick house install, it does NOT equate to battery negative that everybody likes to call ground, but is really the common return for Current flow,
Solar controllers often use the negative terminal as the switched 'charging control' and the positive as the common,
Incidentally IIRC
The Earth is actually positive charged and the clouds are negative (Static charge from atmospheric friction)
Some early automobiles used positive as common to the frame (aka ground) and Negative as the Hot wiring, which is more electrically correct, as electricity aka ELECTRONS travel from Negative to positive, Not positive to negative,
But of course obstinate USA engineers had too do things different than Britton and Europe, so we use a system that have people thinking backwards, and more galvanic corrosion at body parts and electrical connections than would happen if car body frame were at positive potential instead of negative potential
Whoops....according to NOAA I got sky and earth potentials reversed, sky/clouds are positive and earth is negative
So much for My old memory
* This post was last edited 06/19/21 12:56am by MrWizard *   View edit history
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
