RV.Net Open Roads Forum: Tech Issues: 2012 Arctic Fox 990S
 > 2012 Arctic Fox 990S
crewdog1952
Home
Posted: 06/16/21 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Howdy
I have a 2012 Arctic Fox 990S. The panel that tells you tankage levels, battery level and water pump on/off does not indicate, blank when switch pushed. The water pump switch works, just no level indications. The batteries are fully charged the tanks are empty. I pulled the panel and everything looked good.
I can't seem to get a shop manual for the 990S, so at kind of at a loss.
Any Suggestions?
agesilaus
North Florida
Posted: 06/16/21 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Let me break a fact of RV life to you, those panels are mostly worthless. Maybe, only maybe the fresh water tank reading could be right. If you want real readings you have to go to something like the SeeLevel meter system. People try all sorts off cleaning schemes to clean their sensors but if any work, I do not know about it.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Dusty R
Charlotte Michigan 48813
Posted: 06/17/21 06:31am Link  |  Quote  |  Print  |  Notify Moderator
X-2
Roger10378
Goodrich, MI.
Posted: 06/17/21 06:56am Link  |  Quote  |  Print  |  Notify Moderator
If you think that there is a shop manual that would be any kind of help you are dreaming. What you need is a manual for the monitor panel. If you can find a name and number you can usually find something on the internet.
That being said if nothing including the battery level is working then I would think that it is a lack of 12 volts to the panel. The water pump would be a separate 12 volt than the monitor panel. I would look for a blown fuse.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Posted: 06/17/21 07:07am Link  |  Quote  |  Print  |  Notify Moderator
Dusty R wrote:
X-2
Can you two even read?
2017 Heartland Torque T29
3 tons
NV.
Posted: 06/19/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Scrap the cheapo monitor and switch to a reliable and accurate SeeLevel monitor made by Garnet…sensors are external self-stick…
https://www.garnetinstruments.com/product/709p3-seelevel-tank-monitor/
* This post was edited 06/19/21 09:25am by 3 tons *
