RV.Net Open Roads Forum: Holding Tank Treatments and Your Advice on Lubricants
 > Holding Tank Treatments and Your Advice on Lubricants
wopachop
Who run bartertown
Posted: 06/19/21 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
I've been leaning more towards silicone over the white lithium.
Some rubbers dont like petroleum based lubes.
scbwr
North Ridgeville, OH
Posted: 07/18/21 05:32am Link  |  Quote  |  Print  |  Notify Moderator
CRC 3045
The CRC 3045 works well for a lot of jobs.
I also use a good dry lube when you don't want the lubricant to attract dirt and grime.
WD 40 works well for door hinges and other minor jobs as well as removing sticky residue if you are removing decals or labels.
Bottom line is to use an appropriate lube for the job.
For personal use, my preference is a good beer. I believe in supporting Ohio businesses and beers brewed by Great Lakes are at the top of my list. Dortmunder Gold is one you will most frequently find in the fridge along with many other friends. Variety is the spice of life!
Wine is a good "lube" for the wife, but it has to be used carefully or she tends to fall asleep! Perhaps that isn't so bad?????
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
jjrbus
FT Myers FL
Posted: 07/18/21 08:36am Link  |  Quote  |  Print  |  Notify Moderator
The knowledgeable RV people had me spending money on RV tank treatments, then I figured out they were not so knowledgeable. Tank smell inside the RV? The system is leaking and a plumbing smoke test will find the leak. NO chemicals for me. If you have money in your wallet Camping World and WalMart have a product to remove it.
I added Zerk fittings to the holding tank valves and give them a bit of grease every now and then. I really do not care that petroleum may or may not be good for the seals, they are not going to last forever and I do not want to deal with stuck valves. I had my last RV 10 years full timing and the grease did not destroy the seals.
RLS7201
Posted: 07/18/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
The seals are not rubber. The seals are neoprene.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
