RV.Net Open Roads Forum: Holding Tank Treatments and Your Advice on Lubricants
 > Holding Tank Treatments and Your Advice on Lubricants
SweetLou
La Quinta, CA USA
Posted: 06/17/21 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Might be in the wrong category, however I think it could also be a tech thing. What kind of cleaner or holding tank material do you use to help lubricate the valve seals? Are there DYI solutions used or just products that remove sludge? Are there multiple treatments such as holding tank solution then every so often put some other material in to keep seals working? I know about the ice method and traveling down the road, but this does not work if you stay put somewhere for awhile. Thoughts?
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
Posted: 06/17/21 07:09am Link  |  Quote  |  Print  |  Notify Moderator
And outta left field ….
2017 Heartland Torque T29
LouLawrence
Traveling the US!
Posted: 06/17/21 07:10am Link  |  Quote  |  Print  |  Notify Moderator
All you need is water, and plenty of water. No chemicals are necessary to keep your holding tanks working properly. It you absolutely feel like you must use something, Happy Camper is the best (unnecessary) product I have ever used. I only use that when I will be dry camping for an extended period of time and am trying to conserve water usage.
jdc1
Rescue, Ca
Posted: 06/17/21 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Yep. Just water. Once in a while, dish soap, before leaving for a trip to really clean it up.
IAMICHABOD
Sunny So Cal
Posted: 06/17/21 07:55am Link  |  Quote  |  Print  |  Notify Moderator
All you need is water and enough of it and the Geo Method
As for the Lubricants I have found that the the method described in This video does all you need.
I have used both for years and everything has worked well with not one problem.
Former El Monte RV Rental
Buying A Rental Class C
Pangaea Ron
Anacortes, WA, USA
Posted: 06/17/21 07:59am Link  |  Quote  |  Print  |  Notify Moderator
This^^^^
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
valhalla360
No paticular place.
Posted: 06/17/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Unless you are planning to eat out of it, water is all you need. Use plenty of it so the solids float and get pulled out when you dump.
If you are using it regularly, it won't hurt to lube it but not critical. I believe it's when it's not used regularly, that lube is more important. That allows time for things to dry out and turn crusty.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
rexlion
Broken Arrow OK
Posted: 06/17/21 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Most campers lubricate with beer, but some prefer wine or the hard stuff... [emoticon]
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
Pangaea Ron
Anacortes, WA, USA
Posted: 06/17/21 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Yes, but it's so diluted, I'm not sure that it's effective as a lubricant?
rexlion
Broken Arrow OK
Posted: 06/19/21 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on what (or who) is being lubricated! [emoticon]
