RV.Net Open Roads Forum: Tech Issues: Norcold refrigerator trouble
 > Norcold refrigerator trouble
larandjane
Mannford, OK
Posted: 06/17/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
I have a norcold 611 refrigerator in my 2005 HR Savoy. It quit working on AC and now has quit on gas also I replaced the thermistor since it was cheap and easy but it didn’t fix it. The lines are getting hot and you can hear the burner.. Any ideas?
Larry and Beautiful Wife
2005 HR Savoy 29RKS 2007 Chevy 2500
agesilaus
North Florida
Posted: 06/17/21 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Is the display working on the front of the fridge? Take the outside access panel off and clean the burner
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
bobsallyh
Livingston, TX.
Posted: 06/17/21 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure your coils didn't go belly up. Check to see if you have yellow egg yoke looking stuff running down the coils and a terrible ammonia smell.
larandjane
Mannford, OK
Posted: 06/17/21 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
Yes the display on front works the light flashes a code which according to my manual means the refrigerator isn’t working. I had figured that out ??
dougrainer
Carrolton, Texas
Posted: 06/17/21 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
Does the freezer even get cold at all? If not and the gas is staying ON, your Cooling Unit is bad. Even a bad cooling unit(not a leaker) will get the freezer a little cold. Doug
larandjane
Mannford, OK
Posted: 06/17/21 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
There is a little yellow residue around the the bottom of a cylinder that has insulation and tubing inside. Also the freezer doesn’t get cold at all and the front display works and is flashing a code that according to my manual means the unit has failed not owner serviceable. I’m not getting a good feeling about this
Boon Docker
Posted: 06/17/21 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Yellow residue means the unit has sprung a leak. You need to replace the cooling unit.
Posted: 06/17/21 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
Yup That is exactly what happened to me
Two choices Replace cooling unit (less parts cost more labor cost)
Replace Fridge (More part cost lower labor)
Boon Docker
Posted: 06/17/21 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Norcold N611 cooling unit.
They are not too hard to replace. Took me about 2 hours to replace my Domectic unit.
Old-Biscuit
Verde Valley
Posted: 06/17/21 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
That is dried up sodium chromate (rust inhibitor in the coolant)
It is toxic.....work it wet
No blowing with compressed air, vacuuming, brushing etc that can cause 'dust'
Face mask, gloves....spray bottle......work it wet to clean up before you remove/work on cooling unit
US NAVY------USS Decatur DDG31
