RV.Net Open Roads Forum: Seeking refrigerator tips... in AZ and heat is hampering...
 > Seeking refrigerator tips... in AZ and heat is hampering...
Page of 5
groundhogy
PA
Posted: 06/18/21 12:12am Link  |  Quote  |  Print  |  Notify Moderator
.. its ability to keep cold.
I don't know much about these units, but I assume the idea is to keep the back coils cooler?
I have seen one guy with a fan in the outside compartment.
But that's just blowing 110 degree air on the coils.
I am kind of thinking of one of those tiny swamp coolers that they advertise on TV.
Any comments or education welcome.
thanks..
groundhogy
PA
Posted: 06/18/21 12:49am Link  |  Quote  |  Print  |  Notify Moderator
mini swamp cooler.. see...
www.arcticairpurechill.com
MrWizard
Traveling
Posted: 06/18/21 03:42am Link  |  Quote  |  Print  |  Notify Moderator
Fans help, the move more air over the coils, yes the outside air is hot, but the heat exchanger coil is hotter, the more air flow the more heat removed from the coolant, the better the absorption RV fridge will operate
Parking so the fridge side of the RV is not in the afternoon sun helps, put out the awning, hang a tarp, park next to a tree, anything that shades the back of the fridge, helps
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
valhalla360
No paticular place.
Posted: 06/18/21 05:27am Link  |  Quote  |  Print  |  Notify Moderator
If the cooling unit is 150F (not sure of the actual temp but it's pretty hot).
- If there is minimal airflow, the air around the cooling unit may be 130-140F, so only a 10-20F temp difference.
- If you push 110F air in, that's a 40F temp difference which will extract more heat from the cooling unit.
That said, 110F can be problematic.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
sch911
Rochester Hills, MI
Posted: 06/18/21 05:31am Link  |  Quote  |  Print  |  Notify Moderator
I have two 12V computer fans blowing air upward in the back of the fridge. They are mounted about half way up the back of the flue. Getting the heat to rise out of the flue is the key.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
harley-dave
ummm, where are we again..
Posted: 06/18/21 06:35am Link  |  Quote  |  Print  |  Notify Moderator
X2 This is what we did also. Also keep the refer at maximum cold (9) setting, cool inside the coach, shade the vents outside the RV and don't open the refer as much as possible.
Dave
2005 Winnebago-Itasca Sundancer 31C
2010 Harley-Davidson Soft tail Deluxe
2014 Harley-Davidson Street Glide Special
1999 Chevrolet Tracker 4X4
SKP # 121272
larry cad
ohio
Posted: 06/18/21 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Propane refrigerator MUST be level also.
Our Travel Blog
#1Flyboy
California
Posted: 06/18/21 08:24am Link  |  Quote  |  Print  |  Notify Moderator
X3 on fan’s & get side in shade…
otrfun
On The Road
Posted: 06/18/21 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Exterior fans will help. We've found it improves cooling about 2-4 degrees when ambient temps are really high.
We've camped in 110+ AZ heat many times. Even a perfectly operating propane frig with double exterior fans will have trouble maintaining 40 degrees in this kind of heat. If you access the frig more than once every 2-3 hours during the heat of the day you'll be lucky to stay below 45.
azdryheat
Tucson, AZ
Posted: 06/18/21 08:31am Link  |  Quote  |  Print  |  Notify Moderator
It's triple digits here in Tucson and my refrigerator has no trouble making ice cubes. It's plugged in to shore power if that makes a difference.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Page of 5
