RV.Net Open Roads Forum: General RVing Issues: Receiver Hitch for Trailer
 > Receiver Hitch for Trailer
K3WE
Missouri
Posted: 06/18/21 07:34am Link  |  Quote  |  Print  |  Notify Moderator
I have a very specific question:
Is anyone aware of good receiver hitch kits to put a hitch on a travel trailer. I've seen lots of kits for adding hitches to vehicles.
I am wanting a good hitch to use a carrier- but not really interested in triple towing.
I am also a veteran of this: On our first camper I did-it-myself, first with U-bolts through a simple bolt-on receiver hitch (and discovered why that is a bad idea), and then went to a welder who sold me a nice heavy square tube for the bumper, welded the receiver too it and bolted it in place of the stock bumper.
The new trailer has a "better" bumper, but it's welded on AND I do not think the new bumper is quite strong enough (and of course, "the directions" say don't do it.
I should probably cut that bumper off (a bit of a hassle) and fabricate mounting brackets for my old "super bumper-with-receiver" (which I still have).
However if there was a good kit- it could be a time saver of drilling a couple holes and tightening some bolts and not turn a perfectly good bumper into scrap iron.
Thanks.
SKroamcampgrounds
New Orleans
Posted: 06/18/21 07:40am Link  |  Quote  |  Print  |  Notify Moderator
hey there! etrailer.com has lots of good kits and you can filter by type of vehicle and what you're looking to pull. hope this helps!
K3WE
Missouri
Posted: 06/18/21 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Edit: Ok, so far, this is not a great source for hitches that you mount on the camper- at least not the search feature. I am not giving up on them, and will dig deeper, but the "filter" set up is more about hitches that go on the tow vehicle.
Still curious if other folks have experience with this.
* This post was edited 06/18/21 08:05am by K3WE *
fyrflie
Martinez, CA. USA
Posted: 06/18/21 07:59am Link  |  Quote  |  Print  |  Notify Moderator
You might be able to get some ideas from Lippert.
https://store.lci1.com/shop-by-department/cargo-storage/cargo.html
Mounting the rack in multiple places on the bumper could be enough to spread out the load and be a doable solution.
Good luck
K3WE
Missouri
Posted: 06/18/21 08:07am Link  |  Quote  |  Print  |  Notify Moderator
fyrflie wrote:
***Mounting the rack in multiple places on the bumper could be enough to spread out the load and be a doable solution.***
Not a good solution: The carrier gets moved around from our cars to the camper- I am insistent on a receiver for the sake of convenience.
Tyler0215
Iowa
Posted: 06/18/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
If you already have a hitch that works, go back to the welding shop and have it mounted the correct way. No worries.
rirish1
Alachua, Florida
Posted: 06/18/21 08:28am Link  |  Quote  |  Print  |  Notify Moderator
This is how I solved the problem. An adjustable receiver welded to my TT frame. I've hauled 2 bikes to Alaska and back as well as numerous other trips without problem. It is available on etrailer.com
Curt Adjustable Trailer Hitch Receiver - 18"-51" Wide - 2" Drop - Class III - 2"
IAMICHABOD
Sunny So Cal
Posted: 06/18/21 08:38am Link  |  Quote  |  Print  |  Notify Moderator
My son in law used these Safety Struts added to his rear bumper then bolted a receiver to the bumper to carry his cargo carrier,worked out very well.
Former El Monte RV Rental
Buying A Rental Class C
JIMNLIN
Oklahoma
Posted: 06/18/21 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Just a shout out " bolt vs weld" ....our first 5th wheel trailer was a new 1984 26' Aljo by Skyline. It came with the usual thin 4"X 4" tube rear bumper/slinky carrier. Back then bolt on receiver kits were common. I had a weld/fab shop cut the thin tube off and fab/weld back with a 1/4" wall 4"X 4" square tube. I then bolted my receiver to the heavy bumper.
The fab shop fabricated/welded receiver hitches on mostly commercial trucks/trailers. I mentioned bolting my receiver to the new tube but they didn't recommend any bolt on hitch on the back of especially trailer. They saw lots of loose nuts and bolts and elongated holes. Well I was back 6 months later with a loose receiver....for them to weld it in place.
I towed doubles with a 3500 lb bazz boat behind the Aljo 5th wheel trailer.
My next two 5th wheel rv trailer had custom fabed receivers welded in with more cross members and bracing for heavier trailers so I could tow doubles with my 7k flatbed/cargo trailers.
enblethen
Moses Lake, WA
Posted: 06/18/21 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Might look at some of these.
Curt multi fit hitches
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
