RV.Net Open Roads Forum: Technology Corner: Verizon or gmail bouncing email to phone
 > Verizon or gmail bouncing email to phone
Cristian123
Phoenix, USA
Posted: 05/18/22 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
This is why I switched to Boost Mobile. It runs on AT&T & T-Mobile and everything works great. Moreover, I can always call the boost mobile phone number (I found it on this website https://boost-mobile.pissedconsumer.com/customer-service.html) and solve any issue within a few minutes. No regrets.
* This post was edited 05/20/22 02:47am by Cristian123 *
MrWizard
Traveling
Posted: 05/22/22 09:28am Link  |  Quote  |  Print  |  Notify Moderator
I wonder, for those of you that have problems with this form of communication, send from email to phone text,
Are you in your carriers designated coverage area ?
Or
Are you roaming,. Such as getting Verizon on Sprint tower or att on TMobile tower
Knowing this might help clarify the issue
Your phone should have and indicator, either on home screen or in settings
Also roaming can be turned of in settings/networks,
If in doubt, as a test temporarily turn off roaming , if you loose cell service, you are roaming on sn affiliate tower, not using your carrier owned tower,
* This post was edited 05/22/22 09:37am by MrWizard *
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
